inputs 3-8 on 001 loose? or bad cables?
I just got my 001 a couple of weeks ago. With it, I bought some brand new 1/4" unbalanced cables (ok, they're new but cheap). And when I plug those cables on the inputs on the back of the 001 they don't work fine... if I plug them all the way to the end they don't work, then I need to pull them a little bit back and then I have the signal. Is this happening because the inputs are balanced and the cables aren't? Or just because they're cheap a** cables?
------------------ Think Diferente!
Think Diferente! |
Re: inputs 3-8 on 001 loose? or bad cables?
I had the same thing happen last night and had to do the same thing to get it to work.
Log |
Yeah, it's a familiar problem. Actually I once worked with a Digi001 that even had input channels 7 and 8 out-of-phase!
Sometimes I wonder if they build those boxes out from recycled material... |
While we don't recommend any specific brand cables, the 001 is typically tested using HOSA cables. The measured diameter of the TRS and TS 1/4" test plugs is typically 6.30-6.35mm. The length of the 1/4" plug is typically 29.95-30.00mm.
-With that being said, I would suggest you try another type of cable. Brent |
UGH!!! Digi recommends HOSA cables?? That's terrible. I've bought my fair share of HOSA cables in my day, and I'll never do it again. At least 90% of them have gone bad within 6 months of owning them, and the attempts I've made to get replacements have gone completely unanswered.
Nevermore, nevermore. ------------------ Slim |
-Since cable manufacturers use cable connectors of varying sizes (usually by a few millimeters or so), we use a HOSA cable to test the jacks of the Digi001 to ensure proper contact. Remember...this is for testing purposes only and not to track the next Steely Dan record. If you want a cable recommendation: -Monster -Mogami -Switchcraft or Neutrik (for raw connectors when making cables) Brent [This message has been edited by DigiTechSupt (edited May 04, 2001).] |
Right on Brent, my bad.
Humm, now I see... I'm very inclined on making my own cables...
Think Diferente! |
Hum in MBox inputs... Hum Eliminator didn't work, blnced cables didn't... | dl0banter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-17-2011 07:55 PM |
Any issues running Digilink cable in conduit with audio cables vs power cables? | ragbor | Pro Tools TDM Systems (Mac) | 2 | 09-07-2009 10:44 AM |
wats the best trs cables for the inputs and outputs for the mbox mini? | Graffic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-07-2009 05:25 PM |
inputs, outputs, cables..oh my. | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-02-2008 09:01 AM |
Unbalanced cables with inputs 1-4 | Jak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 03-11-2006 04:35 AM |
