Old 08-04-2013, 03:38 AM
pinnacle pinnacle is offline
Default moving automation points
I have some automation points for volume on a track and I want to turn the volume up for all of them. Is there a way to select them all and turn up or do I have to do one at a time?
Old 08-04-2013, 05:17 AM
joachim's Avatar
joachim joachim is offline
Default Re: moving automation points
make a selection that includes some volume automation breakpoints and
drag or Alt+drag them up/down
(Alt+drag will act like a rubber band to the breakpoints outside the selection)
or
track view : volume trim
make selection covering the breakpoints
drag volum-trim-lane up/down
right-click track name : add volume-trim
dragging a selection of breakpoints and other methods :
PT Reference Guide , search for "editing automation breakpoints"
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 08-04-2013, 03:32 PM
or
I tried the first option. When I alt drag the grabber tool turns to a - and deletes points.
The second option when I right click the track name I dont see any thing that says add volume trim??
Old 08-05-2013, 01:36 AM
joachim's Avatar
you first need to make a selection that covers multiple breakpoints
"add volume trim" will be visible once you actually moved the volume trim lane
Moving loop points ThunderKyss Pro Tools 10 4 11-16-2013 05:54 AM
PT 10.3.4 is creating automation points. Rickaudio macOS 7 04-03-2013 01:31 PM
PT 8 Automation Break Points myke2242 Post - Surround - Video 7 04-20-2009 10:17 PM
Keep losing automation points DEXTERITY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-18-2005 05:05 PM
Sync Points: Moving regions according to Mount Royal Pro Tools TDM Systems (Mac) 7 08-15-2001 12:36 AM
