Can\'t creat new session on DISK!
POWERMAC G4 1G/768mbRAM HD1/protools 6.2.3
I just seperate my internal Disk into two partition. one for startup and the other for reording. (mac os extended format) and when I want to creat new session on the recording disk , it always shows"session should be created on the audio volum disk" but I can creat on startup disk and works no problem. n if I move the session from firewire disk or other place into recording disk it also works i have use disk utility to first aid but still nothing happened |
Re: Can\'t creat new session on DISK!
Is the drive set to "R" rather then "T" or "P" in the workspace window of Pro-Tools ??
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
I had a similar problem on this before it showed it was a record volume in the WS window I toggled it back and forth (Between Transfer and Record) and the drive came back OK.
it works!!!
thanx a lot! |
Consolidate creates and saves session to old disk (osx disk) | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-16-2008 11:46 AM |
bluescreens if I creat a new session | Robs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 01-28-2006 03:50 AM |
Cannot open session or creat new session ! | producerjames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-02-2005 09:50 AM |
Disk Allocation Problem -- PT Session can have two disk allocations?? | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-26-2003 07:22 AM |
Can't creat a mix desk-error | billg2 | Pro Tools TDM Systems (Mac) | 1 | 09-20-2001 03:02 PM |
