  #41
Old 05-31-2020, 08:31 AM
Magnetic Magnetic is offline
Default Re: Graphic freeze on playback
Solved...so far.
Quite Pro Tools if open.
Go to ~/Library/Preferences/Avid/Pro Tools and delete UsageAnalytics.pref
Empty Trash and relaunch Pro Tools.
Fingers crossed....
  #42
Old 05-31-2020, 08:56 AM
Tim R. Tim R. is offline
Originally Posted by Sixto6 View Post
Turning off "send anonymous pro tools usage data to avid", rebooting PT with network ON works for me.
This worked for me too. No need to trash anything. Just turn off the pref.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
  #43
Old 05-31-2020, 11:51 AM
simontheoracle simontheoracle is offline
Issue should now be fixed.
  #44
Old 05-31-2020, 02:07 PM
Oli P Oli P is offline
But what was the issue?
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
  #45
Old 05-31-2020, 03:11 PM
Fishbone Fishbone is offline
The culprit was indeed the infamous "send anonymous data to avid" after all.
Seems to be something with Avid servers that was fixed:
https://www.pro-tools-expert.com/hom...eid=7df9d770ef
They say now it's "save" to check the option to send data back on again... yeah, Avid, will do it right now for sure...
  #46
Old 05-31-2020, 07:45 PM
gub gub is offline
yeah just checked and all things seem back to normal...... so far
  #47
Old 06-01-2020, 04:43 AM
Brian Hudson Brian Hudson is offline
Hilarious he he
Brian Hudson
  #48
Old 06-01-2020, 02:39 PM
stevenbb stevenbb is offline
it works by just turning off "Send anonymous ProTools user data to Avid" from operation located under preference.
It must to do with the new apple security update broking ProTools sending out stuff to Avid.
Early 2015 Macbook Pro 13" 2.7 GHz Dual-Core Intel Core i5
Amount of Memory installed: 8 GB 1867 MHz DDR3
OS version: Mac OS 10.15.5
Avid hardware model:- Artist Mix
Pro Tools 2020.5
High Sierra graphic freeze reichman macOS 2 10-02-2018 01:03 PM
Pro Tools 10 HD (Cursor Freeze/Playback Freeze) vinlance Pro Tools 10 1 07-13-2013 11:40 AM
Fixed: Intermittent Graphic Freeze When Using Pro Tools crizdee Pro Tools TDM Systems (Mac) 4 10-03-2007 07:25 AM
Automation edits during playback crashes and graphic freezes Chris A Pro Tools TDM Systems (Mac) 0 08-12-2007 10:27 PM
graphic freeze...all gone?? ThomasPMusic Pro Tools TDM Systems (Mac) 20 03-30-2007 09:53 PM
