Old 04-27-2022, 08:19 AM
Isdpcman Isdpcman is offline
Default Re-install Pro Tools 8.0.4 LE on Windows 7 SP1
We have a user that had Pro Tools 8.0.3 installed. The system hard drive died and we replaced it with an SSD. We installed Windows 7 (home) 32 bit and all the updates. We tried reinstalling Pro Tools 8.0.4 but it fails with the error that it requires Windows XP SP3 or Vista. We tried compatibility mode for XP sp3 and Vista and it still fails with the same warning.
Is there any way to get this reinstalled? Will it run on Windows 10 better? Any help is appreciated!
Old 04-27-2022, 10:07 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Re-install Pro Tools 8.0.4 LE on Windows 7 SP1
IIRC, 8.5 and Windows 7 Pro 64 Bit. Check here.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-27-2022, 02:11 PM
sw rec sw rec is offline
You have to install 8.0.3, and then immediately install the 8.0.5 updater. But yes, that 8.0.5 update was written for 64-bit Win 7.
I don’t imagine it’ll run on Win 10 at all….I seriously doubt your PT interface (you didn’t specify what it is) has Win 10 drivers.
Trying to install pro tools LE on Windows XP emzycollins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-07-2024 04:10 PM
Can't install Pro Tools LE on Windows XP emzycollins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-01-2016 05:07 PM
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
HOW DO I INSTALL Pro tools 8.0.4 LE ON WINDOWS 7 32 BIT Rski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-15-2011 08:02 PM
Pro Tools LE 7 + Windows 7 = can't install :( downing3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2010 01:33 PM
