Old 04-17-2011, 06:01 AM
the19thbear the19thbear is offline
Default Crackling when moving windows??
ey. Just upgraded my daw.
Specs:
Nvidia 8400gs
I7 3,5ghz quadcore
4gb ram
win 7 32 bit
2x6dsp cards - soniccore
Running pro tools 9
64-1024 buffer
If I load a synth(forgot the name.. The analog tube synth) in pro tools and play, I get glitches when playing.
When I move windows around while playing I get alot more crackles..
If I minimize the pro tools window I get no crackles.
The CPU meter is always about 3-5% so that's not an issue... Even though it jumps up and down a bit when I move windows around.
This also happens without using a synth and just monitoring inputs via pro tools or mixing.
I tried disabling all extra graphics stuff but I'm new to win7 and dont know all the secret menus.
Thanks alot!!:)
Old 04-17-2011, 06:04 AM
Default Re: Crackling when moving windows??
And by the way.. Everything works fine in reaper.. Is pt really picky about graphics cards?
I gave already done the suggested digidesign tweaks ( optimize for background services
, disable power management etc)
Will do a Sandra report later this week
Old 04-17-2011, 11:55 PM
MuzicMan MuzicMan is offline
Hi there,
I have the same issue with crackles when moving windows. As far as I understand it and after speaking with Avid, it seems ProTools does not play nice with Windows Aero. Also, my system insists on putting the IRQ of the audio interface on the same IRQ as the video card. I haven't found a way to force Win7 to change an IRQ yet, but I'm still investigating.
The current workaround is to disable Windows Aero when PT starts. Right click the PT icon on the desktop you use to start PT and go to the compatibility tab. Make sure both the Run as Administrator option and the Disable Desktop Composition options are selected. PT will now start after temporarily turning off Windows Aero and your clicks should disappear.
Best of luck!
Old 04-18-2011, 12:25 AM
Already tried the disable suggestion. Still doesnt work thanks though!
I have the same irq problems as well. I'll be installing win xp later today and see if it works better.
Keep up the suggestions!!
And did this trick work for you?
Old 04-18-2011, 07:04 AM
daeron80 daeron80 is offline
Same thing here. Reaper works flawlessly (and did even before I disabled Aero). Pro Tools crackles when making any changes to windows or even when resizing a track. The only workaround I've found is, don't change anything during playback. It's like the old joke, "It only hurts when I laugh. And the doctor says, 'Don't laugh.'"
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-18-2011, 07:16 AM
Makes me already hate pro tools... The reaper installation file is about 5 megabytes and is really stable and has tons of features.. And is not computer-picky at all.
Pt costs alot, fills up alot of hd space and is really picky!
Aaaarghhhhh drives me mad!
Avid better come up with a solution for this!
sunburst79 sunburst79 is offline
And in other news Windows 7 just surpassed Windows XP as the worlds most popular operating system. Proper GUI support would be nice. And yeah that includes Aero.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-18-2011, 07:36 AM
Vote for the bug fix here.
David J. Finnamore
Old 04-18-2011, 11:20 AM
what are your configurations? could this be an nvidiaa gpu problem?
Old 04-18-2011, 12:43 PM
I have an ATI 4300 series card. So it's not limited to Nvidia.
David J. Finnamore
Problems with crackling / static when recording (Windows 7) Mbox2 zorkiii Windows 24 11-08-2015 08:44 PM
moving to windows vonNoblemachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-01-2008 11:02 AM
Moving to windows McGas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-19-2008 03:25 PM
Mbox and windows xp crackling sound Jakob Frandsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2004 05:05 AM
Moving from Windows 98 to XP brianpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2003 01:41 AM
