Re: ProTools 10 and Mbox 3G Problems on Windows 7 (64 bit)
I'm sorry to say that holding 'N' down with its resulting window still doesn't list the Mbox as an option.
I also took out the 2GB RAM stick and that didn't solve the problem. Any other ideas? Thanks. |
There is probably a simple solution to this but as I am using Macs I am just trying to help you as best I can. Installed latest drivers I expect and still no go?!? Leave the 2GB ram out of this until we get you going again. Try the thread with optimizations and hollaback
Holding the 'N' key doesn't solve the problem. Switching USB ports doesn't either.
I'm not sure what you mean by 'try the thread with optimizations.' I'm still looking for help. Thanks. Last edited by Jmo9; 05-25-2013 at 08:54 AM. Reason: more info |
http://duc.avid.com/showthread.php?t=300050
I went into Uninstall Programs and clicked Pro Tools then the Change tab . I then ran the Repair option and the computer installation came up with this message:
MDAC 2.7 sp1 cannot be installed on this machine. MDAC 2.7 Sp1 requires any one of the following configurations: Microsoft 98 with Y2K Update and Internet Explorer 4.01 SP2 or later Microsoft Windows Millennium Microsoft NT 4 SP5 (or greater) and IE 4.01 SP2 or later Microsoft Windows 2000 Microsoft Windows XP Setup will exit now. Please restart the Setup after installing the necessary updates to this machine. I then went to the microsoft website and downloaded what I thought was the update and ran it, restarted the machine, but the same message popped up when I tried to repair Pro Tools again. Any thoughts about this? I tried to search online for answers and only got further confused. Thanks for any help. |
#16
It seems I need to turn to one of Avid's technicians to try and solve this problem.
As a final effort to fix it myself I uninstalled PT 10 upgrade and re-installed PT 9 from the disc. Problems remained the same. Thanks to those of you that tried to help. |
#17
Good Luck and hope you get up and running soon Best Regards Chris
#18
Have you tried running the Mbox on it's own power supply?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Mbox 1.1.8 Driver Problems / Windows 8 | jimst57 | Windows | 9 | 07-31-2013 12:11 PM |
Problems With MBox 2 mini on windows 7 | zacharyah88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2009 01:39 PM |
MBox 2 Pro problems - no sound (Windows XP Pro) | charliemizza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-13-2009 10:53 PM |
AutoTune 4 - ProTools 6.4 - Windows XP problems | drmandel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-02-2004 11:36 AM |
Pro Tools 6.1.1/MBox/Windows XP Problems! Help! | Josh Jagdfeld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-26-2004 07:47 AM |
