Old 04-12-2022, 10:37 AM
blinches blinches is offline
Default Clip Gain Workflow
Ok so a question to all of your Pro Pro Toolers...
Let's say you're manually de-essing vocals with clip gain, what's your workflow? you click 3-4 times each time to create all the breakpoints? one would think there would be some kind of shortcut or hack to just do it with one action or two... also, I know you can select a region and lower it but that creates a 90 degree angle and causes clicks and pops within the clip, how do you handle this the fastest way without needing to click so many times? or are we all just doomed to clicking to infinity?
Thanks and appreciate any insight!
Old 04-12-2022, 11:04 AM
Sonopolis Sonopolis is offline
Default Re: Clip Gain Workflow
Setting the preference to 1dB steps helps to speed up things and CMD+Shift+x is your friend to make ramps. Also, you don't need to see the Clip Gain line to work with Clip Gain.
Old 04-12-2022, 01:23 PM
BScout BScout is offline
Use volume automation.
Then select your clip and choose to convert volume automation to clip gain.
Old 04-12-2022, 04:46 PM
Sardi Sardi is offline
That’s an Ultimate only feature. Looking at OP’s profile, it appears they’re on Standard.
Old 04-12-2022, 04:47 PM
I often use Clip Gain for de-essing. I swipe across the sound and hit the B key(with keyboard focus enabled). That separates so I have a clip and then use the mouse to adjust Clip Gain for that clip.
Old 04-12-2022, 05:03 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Linear cross fades between clip gain regions is the same as a volume ramp. I don't know if its a quicker workflow but its another thing to have in the toolbox.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 04-13-2022, 08:27 AM
Select across the desired area, "B" key to separate, Shift-Opt-down arrow for the desired amount of clip gain, select across and command-F to apply a preset linear 10msec Xfade across the boundaries. One can easily program this into a Keyboard Maestro or Soundflow macro so it's one keystroke/button.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 04-13-2022, 03:48 PM
Which is exactly what I did. It’s my DeBreath button/macro.
Old 04-16-2022, 09:36 PM
Awesome, thanks for the suggestions everyone.
Clip gain o Gain plug in Camilo Toledo Foro en Español 3 03-22-2017 02:10 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip gain multiple clips workflow cjwalker Pro Tools 10 0 10-12-2012 02:53 AM
