Old 03-31-2005, 05:20 AM
slicvic1 slicvic1 is offline
Default partition hard drive
i just got a 250 gig lacie hard drive that i want to use mainly for pro tools and maybe later on use for videos, my question is should i partition it into more then 1 drive(if so how many?) or will it be fine as just 1 drive?
Old 03-31-2005, 05:45 AM
JamesV JamesV is offline
Default Re: partition hard drive
I've partitioned my 160gb audio without issue, however I've heard there might be a loss in performance. Have not noticed a difference.
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al
Old 03-31-2005, 01:26 PM
mkosacek mkosacek is offline
partitioning of a single drive is really nothing more than organization of your files. Can you handle folders or do you want separate drive letters (or mounts, etc)? From a performance standpoint, its still a single spindle. Unless you are doing video and audio simultaneously (and if you are you should invest in another drive) you should not see a performance hit. also, don't try to split a PT session across 2 partitions of the same physical drive, that will just make the head seek back and forth more often and further, causing slower disk reponse time (higher latency!). You will probably see decreased performance vs. a single partition.
Pro Tools 2022.9
UAD Apollo 16 (v10.1)
Dell XPS 8940 (i5-11400)
Win10
www.studiodrumtracks.com
www.doubledogrecording.com
Old 04-01-2005, 07:44 PM
Good advice above. I would partition the drive in half for "housekeeping". This allows you to move files from one "drive" to the other so you can defrag or reformat either partition. I split a 160 to 2x80gig and its been fine.
Old 04-01-2005, 08:06 PM
spkguitar's Avatar
I think Digi actually recomends partitioning larger drives: previous thread
You should consider partitioning that 240 gig drive into 3 80 gig volumes. You'll probably see better disk performance as it cuts down (by 66%) on the disk space Pro Tools has to look at when searching for files to playback.
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Partition Hard Drive jimidalliance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2005 10:44 AM
How to partition the hard drive on my new PC? rossscarbro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 08:53 PM
2nd hard drive - partition ? Pretender Digidesign Hardware & Software 2 09-07-2003 03:23 AM
Hard drive partition? limbochef Digidesign Hardware & Software 1 04-21-2001 09:21 PM
