Yellow Strike with ProTools 9
I use Strike as my drum machine on my G5 with 8.0.0 cs3. I recently purchased a quad-core Mac Pro running 10.6.4 with Pro Tools 9. When I tried installing Strike from the discs, it loaded correctly, but the interface of the plug-in itself is yellow and completely useless. Is there a fix to get Strike working properly with Pro Tools 9? Any help would be greatly appreciated.
~Buck Brundage |
Re: Yellow Strike with ProTools 9
most likely, strike needs an update for your new OS.
check older thread here: http://duc.avid.com/showthread.php?t=242383 |
i have this problem too.
do you find a fix? the updates are all taken down, so the older thread is no help. |
Try reinstalling Pro Tools with the old version of Strike installed. The PT install upgrades certain Digi/Avid plugins. Not sure if strike is in that list, though.
That update did the trick. Thank you very much
Tony |
Strike is YELLOW | raydsr | Virtual Instruments | 5 | 02-01-2011 07:31 PM |
Yellow Sreen - Strike | doppler58 | Virtual Instruments | 6 | 05-03-2010 09:10 AM |
Strike Yellow Screen of Death. Help! | sjaudio | Virtual Instruments | 4 | 06-06-2009 06:06 PM |
Strike colours are yellow | billos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-09-2009 10:05 PM |
Strike graphics all yellow? | silentjdf | Virtual Instruments | 5 | 04-11-2008 05:49 PM |
