Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 06-21-2020, 05:34 PM
clutch clutch is offline
Default Can't open PT after upgrade to 2020.5.0
I upgraded my main studio machine from 2020.3 to 2020.5 a couple of days ago, but now whenever I try to open PT it says the "Subscription License Has Expired" and to plug in an iLok with a license on it.
My iLok with the PT Ultimate Perpetual license is plugged in (I've tried multiple USB ports on the computer). Have tested with other DAWs which use plugin licenses stored on the iLok and they all work fine.
Ilok License manager sees the licence just fine (I've deactivated and re-activated it to the iLok just in case).
I've tested the iLok on my laptop with PT 2020.3 and it works as expected.
Trashed PT prefs, rebooted multiple times.
I've just re-installed PT and am still having the same issue.
Can anyone shed light on what my issue may be? I'm sitting here with a client unable to get any work done...
Many thanks,
Chris
He used to cut the grass...he was a very nice boy...
Old 06-21-2020, 05:49 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Can't open PT after upgrade to 2020.5.0
Please check the Release Limit date on your license, because if it tells 2020.5 cannot be authorised you need to renew update plan.
Janne
Old 06-21-2020, 05:51 PM
In the products section of my.avid.com, it says "Your Software Updates + Support Plan expires on Mar 31, 2021".
I just re-purchased the support plan a couple of months ago!
Old 06-21-2020, 05:52 PM
JFreak's Avatar
Please check that detail anyway. If it is old date you need to synchronise your license key and if that does not work contact Avid Support
Janne
Old 06-21-2020, 05:57 PM
Thanks very much for helping out so quickly Janne!
Where do I find the release limit date detail?
JFreak's Avatar
Click the details of your license open in ILM
Janne
Old 06-21-2020, 06:05 PM
Hi Janne, yes - that was it! Can you please tell me how to synchronise my license key?
Old 06-21-2020, 06:06 PM
JFreak's Avatar
There should be a way to click on the license key and do it, but if that doesn't work deactivate the license and then activate again
Janne
Old 06-21-2020, 06:18 PM
Unfortunately I can't see anywhere to synchronise the key, but I have deactivated and reactivated with no luck.
Also tried just using a Cloud session with the license off the iLok but that is not working either.
Time to call support I guess. Now to try find where my ASC code is. I keep going in circles in my.avid.com trying to find a place where I can get one.
Old 06-21-2020, 06:19 PM
JFreak's Avatar
Don't need ASC as you have active support plan. Start from here.
Janne
PT 11 upgrade to 2020 - install/HD setup advice? Cruz Azul Pro Tools 2020 8 06-08-2020 08:12 PM
PT 11 upgrade to 2020 or new licence? Cruz Azul Licensing & Accounts 11 06-03-2020 03:45 AM
Pro Tools 2020 on an upgraded 4,1 Mac Pro worth the upgrade? tbone63 Pro Tools 2020 13 05-10-2020 12:40 PM
Updated to 2020.3—now sessions open with half the plugins disabled + warning kirkbross Pro Tools 2020 6 04-26-2020 07:35 PM
Cheapest way to upgrade PT HD 11 to pro tools ultimate 2020? protoolsuserman Pro Tools HDX & HD Native Systems (Mac) 25 04-20-2020 03:12 PM
