Disabling PCI Parity
Hi everyone! New user here. I am just setting up my 001 and have an ASUS CUSL2-C, PC133, AGP 4X motherboard. Does anyone out there know if it is possible to disable PCI parity on this beast? Apparently (per the 001 manual) PCI parity checking slows down the PCI bus and probalbly also the recording process. There is a few PCI related options in the BIOS but none of them are related (as far as I can tell) to PCI parity. I want to optimize my sytem for the 001 as much as possible before I start recording. Thanx in advance for any help! T-Man
T-Man |
Re: Disabling PCI Parity
T-Man,
I hate to tell a new guy to ignore the manual, but do. PCI parity is part of the PCI spec and should be left turned on. It does not slow PCI transfers. I beleive that manual actually says it's OK to leave it turned on if your machine doesn't have a way to turn it off, and I think that most of us running here have PCI parity enabled. (I can turn it off, I just don't.) Go have some fun!! ;-) Take care, Mark |
The only problem I've ever heard about from leaving PCI parity enabled is that the system will not boot at all with the Digi 001 installed in a PCI slot. I read that information somewhere either on Digidesign's Website, or here on the DUC a while ago.
So, if your PC boots up don't worry about PCI parity. Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
I haven't seen anyone with an ASUS motherboard that would allow them to disable PCI parity. I would however disable it if it were available, on the assumption that the start up guide is correct. I haven't had any problems without disabling PCI parity and I do have an ASUS motherboard
Win XP: BIOS disabling or Device Manager disabling ?? | mandal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-23-2007 03:11 AM |
pci-parity and plug ins | jon robbins | Digidesign Hardware & Software | 1 | 07-19-2001 02:28 AM |
pci parity | Seanorourke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-30-2000 11:33 AM |
PCI PARITY | J Forsman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-24-2000 12:15 AM |
Question about Disabling PCI parity in BIOS | Echo studios | Pro Tools TDM Systems (Win) | 2 | 11-03-1998 12:36 AM |
