PreSonus Tube Preamplifier Help
Not sure if this is in the right section, couldnt find the sub forum.
I recently bought the Presonus Tube Preamplifier, seen here: http://www.zzounds.com/item--PRSSTUDIOCHANNEL And I'm not sure how to get the right settings for the type of music I do and a bit lost. I do hip hop/Rap music with Singers included on Hooks every now and then and just looking for a standard good Medium/warm sound. Can anyone help me achieve this? Dont wanna start recording till I get it down right. Thanks in advance! TUBE PREAMP Gain: Tube Drive: COMPRESSOR Thresh: Ratio: Attack: Release: Gain: PARAMETRIC EQ: Low: Mid: High: Level: |
Re: PreSonus Tube Preamplifier Help
Big,
Play with it till you like what you hear........ I think most rap vocals are pretty compressed so quick attack and release ratio 6.1 but mainly flavor to what you like to hear...... If it sounds good to you....do it. Then demo it across some verses to hear how it sounds in the mix. Don't forget to scoop your main mix to help your vocals sit right and tight. WWW.airusersblog.com Register for like 15 bucks and get tons of free samples and hits and loops and videos to help you do what you do.......
YYR,
yes, I deff plan on doing that. But, I would like to get at least a standard setting going first so I'm somewhat CLOSE to where I should be at, then adjust from there to the way I like the sound. So any help is much appreciated. |
Here's my suggestion. Start with the compressor and EQ bypassed. Set the GAIN for proper signal level on your audio track(which is just into the yellow). Now add the compressor. Set ratio to 2:1 and go easy at first(you can always add compression with plugins, but you can't remove it if its over done). Set threshold so you hit 4-5db of reduction on the peaks. Adjust the compressor output to make up any level lost by the GR(IOW, get the recording level back to just into the yellow). As you get the feel of how the compressor works, you may want to try upping the ratio to 3:1 or 4:1, but I wouldn't go past there unless you are looking for obvious "squash". As for the EQ, I would not track with any EQ other than a hi-pass at around 125Hz(give or take depending on the range of the singer). Adding EQ with plugins works great, is easy and doesn't commit you to something that might be a mistake when it comes time to mix.
On compressor output you mean the gain right? How does that work? I know you gotta make up for whatever you reduce. Also you said 125 Hz on the Hi pass? It only has ranges from 2k to 20k. Assuming you're talking Freq level? |
Try the 80HZ button then
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Yea, it has the 80hz button.
What does that exactly do? |
From the Presonus Studio Channel manual:
Sorry for the lazyness... Thanks
Presonus Firestudio Tube with PT9 | nohayniunnick | Pro Tools 9 | 6 | 11-24-2010 07:43 PM |
presonus tube pre amp "tube" | Edson | Pro Tools TDM Systems (Mac) | 4 | 01-19-2007 10:20 AM |
presonus tube pre amp | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-18-2007 09:44 AM |
Presonus Tube Pre and 002r | Joe Evans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-24-2004 01:27 PM |
Peavey VMP2 discrete tube preamplifier | bigtree | Tips & Tricks | 6 | 08-29-2000 08:53 PM |
