CPU usage jumps, -9128 errors start
So in the last few days I've started having this problem.
A song will play through fine 3 or 4 times. CPU usage hovers around 19-20%. However, after stopping the 3rd or 4th playback through a song, the CPU usage jumps to over 45%. Once I restart playback, the CPU usage drops back down to ~25% during playback but jumps up again once playback stops. However, after the CPU usage goes up I start getting -9128 errors and dropouts, making the session unusable. PT 9.0.5, Win 7 64bit, Lynx AES16e. Cheers. |
Re: CPU usage jumps, -9128 errors start
Having a bunch of these errors myself. You haven't given anywhere near enough info, but what works for me on an i7 950 rig; go to Setup>Playback Engine and click on Host Processors and select half the cores available. Mine shows 8 cores(i7 quad with hyperthreading enabled). Selecting 8,7,6 or 5 cores all give lots of 9128 errors with stopped playback. Selecting 4 cores at 95% appears to be running great at the 64 buffer.
It happens to me with 4 (out of 8) processors selected.
Same thing, after the third playback CPU jumps up and I start getting errors. |
My Mac was doing similar things and it was a plugin denorm issue.
Try bypassing certain plugs and watch your CPU RTAS meter to see how it affects your system, (my problem ended up being speakerphone, and a dither plugin in the slot before it solved my issues). Its worth a look.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
hello all!! im new to protools and have the same problem as most here. the popping sound!!! im sure you have tried everything with no luck. right? well my friends the problem is solved!!!!! for windows 7. this may work on other os ..ok here you go!! if you notice when you minimize windows while there is playback the popping stops right? this is the result in most cases...try it.. see if it helps..ok, lets assume that worked..now for the permanent fix!!! go to computer under start menu..go to system properties. click on device manager. click on display adapters. then right click your video card and click on disable. then restart your computer... when you go to run protools now. the popping is gone!!! so , it seems to be a problem with the windows 7 video card driver update being compatable with protools se. i tried just uninstalling the driver, but there were video issues. so by disabling the device but issues were resolved. i hope this helps others. please post a response if it did help you!!!! this was days and hours of trouble shooting. i have verified this result 5 times over before posting.. ok, now get recording!!!!!!! |
HDN jumps to high CPU usage | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-30-2013 10:00 PM |
Session freezes and CPU usage jumps to 95% | highrisenola | Pro Tools M-Powered (Win) | 8 | 01-19-2012 03:31 PM |
CPU usage jumps to 100% when saving if edit window minimized | frantik | Pro Tools M-Powered (Win) | 20 | 10-25-2009 05:22 PM |
System usage meter jumps | kaotikmuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2004 08:26 PM |
CPU usage jumps up while doing nothing!! | Andrew B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2003 11:14 AM |
