Old 03-26-2001, 07:38 AM
jjelduce jjelduce is offline
Default Why does 5.1 take so long to start after hitting PLAY?
I just upgraded to 5.1 and I found that there is a delay of about 2 seconds when i have as little as 12 channels in record and i hit the space bar to start playing the track. Whats the deal? I didnt have this in 5.0.1 and nothing in my rig has changed! I used to hit play and no matter how many tracks i had in record (up to 60) and the session would immediately start playing. This is killing me when I am trying to do fast punches. I feel like i am working on a Studer A80 again! Please help! "mad"
JJ El Duce'
Always droppin' hits yo!
Old 03-26-2001, 09:28 AM
uno1234 uno1234 is offline
Default Re: Why does 5.1 take so long to start after hitting PLAY?
Set the limit record time to 5 minutes in the preferences menu. It might have changed on installation.
Old 03-26-2001, 10:41 AM
Also make sure that your DAE buffer setting is set to 2.
Rail
Recording Engineer
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-26-2001, 11:30 AM
blairl blairl is offline
Are you using any RTAS plug-ins? There is a larger latency issue with RTAS plug-ins due to the way they use the CPU for processing.
Old 03-27-2001, 07:17 AM
Charles Deenen Charles Deenen is offline
Check your memory control panel. If this is set above 1000, that will cause a playback delay
-dc
Old 03-27-2001, 08:42 AM
swablar swablar is offline
The "Limit Record Allocation" pref set too high or defaulted will slow things down if your recording partition is really large (18 gig+)
PB Buffer should be 2 on any PT system except PT III hardware
Disk Cache at 512 in the Memory Contorl Panel
** but I 've seen this one a lot-> make sure you don't have the "2 BAR" button on in the transport. Open you Transport Window and display all 3 sections of it. The "2 BAR" button automatically gives you a 2 bar pre-roll and if you use certain keypad configurations and/or quick keys its pretty easy to turn on accidentally.
also, make sure Pre-Roll is off and trash any old PT (prior verisons) prefs
satisfaction guaranteed
Old 03-27-2001, 10:19 AM
Baixo Baixo is offline
Are you using HFS+ disks? If so, they take longer to prime and someone else mentioned the cure: limit your disk space allocation to under 60 minutes.
PT 8 delay when hitting spacebar to play irthwirm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2009 07:56 PM
hitting play does nothing CCash Pro Tools TDM Systems (Mac) 6 07-19-2005 09:23 PM
Hitting Space Bar don΄t Start! in PT 6.9 Diegomusica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-15-2005 09:23 PM
mac freeze and crash when hitting play randyE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-26-2004 03:21 PM
Why is there a 2 second lag when hitting play on the transport in 5.1? jeffjuliano Pro Tools TDM Systems (Mac) 3 04-01-2001 12:57 AM
