Old 10-07-2005, 08:44 PM
trackfive trackfive is offline
Default Install just the CoreAudio driver for Mbox 2?
I installed Pro Tools LE 6.8.1 on my dual G5 1.8 with 1.5gb ram and it was a complete DOG compared to what I'm used to with Logic Pro 7, performance-wise...felt like i was back on my 001 with my G4 400. 1 instance of GuitarRig in PT had the CPU meter at about 50%...in LP7 it would hardly put a dent in it...that's using the same buffer size in each app. I uninstalled PT using the installer/uninstaller and now I just want to install just the core audio driver so I can use the MB2 with LP without loading on all the Pace junk and PT again.
Does anyone know if there's a way to just install the CoreAudio driver using the CD that comes with the MB2? I see in the downloads section on digi it says you can't use the stand alone driver there with the MB2. TIA.
Old 10-08-2005, 05:29 AM
vf124 vf124 is offline
Default Re: Install just the CoreAudio driver for Mbox 2?
I don't believe you can ... the CoreAudio driver is specific to the MBox II ...
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !!
Why install CoreAudio Driver Mikew1061 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-19-2009 03:25 PM
should i install the coreaudio driver w/ ptle 8 & mbox 2 pro? mdo9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-31-2009 08:33 AM
Installing the MBox 2 Pro Standalone CoreAudio Driver? Alan Brownstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-11-2007 02:41 PM
Mbox 2...coreaudio driver cant find hardware Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-31-2006 06:12 PM
6.1.1 CoreAudio-plugin and driver-install both? Raymond Hardy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2003 10:37 AM
