about to upgrade to new computer, HD Native, PTHD 10...thoughts on build?
hi all-
having done some research...it is time to upgrade my old system (PT HD PCI-X on an old Q6600.....still running Win XP + PT 7.4) looking at: 2600k i7 CPU Asus P8Z68-V Pro mobo (based on recent success stories posted here) Corsair XMS3 memory OCZ Agility SSD (for system drive) Windows 7 Home Premium (i'm fine with 16gb RAM limitation) anything look fatally bad here? good chance that this will work with an HD Native card? thanks, jon |
Re: about to upgrade to new computer, HD Native, PTHD 10...thoughts on build?
That 16GB cap might bite you in the butt with Disk Caching support with Pro Tools 10. And I'd discard that SSD. Last I heard SSD was still not Approved by Avid as an audio nor system drive. Ummm... you're not prepared to wait for Intel Core i7-3xxx (6-Core) LGA 2011 X79?
Aaron Mulqueen - 001 HD Native |
Check my sig, your in my exact situation i was in 3 months ago, i had a q6600 and then upgraded.
Your prob not going to like my advice but i would suggest holding out till PT 11. I have 16gig ram just sitting there doing nothing due to pro tools 32bit, and no standalone asio drivers either for hd native, win7 64, to run virtual instruments standalone. I still have the same buffer errors etc. I fear i upgraded at the wrong time. It might be a year or so by the time pt11 comes, by then my computer will most likely be 'standard' If you wait, for the same price your willing to spend now, you'll be able to get a kick arse, totally up-to-date system, that you could actually utilise within pro tools. Thats just what id do if i had a second chance. I stupidly was banking on pro tools 10 being 64bit, i was wrong.
Windows 7 Pro 64-bit Intel Core i7-2600K @4.5GHz QUAD 8 MEG CACHE W/HT LGA1155 Motherboard dual channel DDR3 TI firewire (Sandy Bridge) Mushkin DDR3 16G RAM Pro Tools HD Native 9.0.5 C24 Eleven Rack Lynx Aurora, LTHD UAD2 Quad Neve ----------------------------------------------------------------- MacBook Pro 2.3GHz Quad-core Intel Core i7 8GB 1333MHz DDR3 SDRAM Pro Tools LE 8 Glyph Tech GT050Q 003 Rack Mbox2 mini |
Intel released new CPUs and the X79 chipset today.
According to Tom's Hardware there is a 17% performance increase overall.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
PTHD10 has a 64bit ASIO driver.
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
i think it's a safe bet that a slightly overclocked 2600k on a known-to-be-functional motherboard will be more CPU power than i'll want or need. i'd like to upgrade now...lots of new plugins and softsynths i would like to use. and clip gain would be such a timesaver.... |
I'm in exactly the same boat. Just threw down on PT HD Native, coming from TDM pci and the Q 6600 quad as well. I can reuse my video card, drives, case and power supply and really need just the motherboard, CPU, and ram. Wondering what I can get for a budget of about $800. Suggestions?
Thanks! |
But keep in mind that the new chipset and CPU have quad channel Ram.
The 2600k looks like the CPU ill be going with, any recommendations for a great motherboard? As said before, stability / compatibility is key.
Thanks, Tommy |
From my recent experience, I would avoid a z68 chipset. I bought a GIGABYTE GA-Z68XP-UD5 mobo a few months ago and my system still is getting errors (-9092, and -9093) everytime I try to playback or record. I'm not saying it is definitely the mobo, it could just as well be a driver or a utility causing the errors, but I have narrowed down the cause of problems to one of those things.
I'm surprised to hear success stories with the Asus P8Z68-V Pro mobo, I would be interested to know if there are any significant differences between the Asus P8Z68-V Pro mobo and the Gigabyte Z68 mobo I have.
Dwight, you ignorant slut |
Thoughts on computer build | freezejoin | Windows | 8 | 04-02-2012 09:37 PM |
PTHD 9 native not being recognized after computer is shutdown | nme1 | macOS | 3 | 03-24-2011 12:31 PM |
Losing PTHD 2 to get HD Native...anybody? | acmost | Pro Tools 9 | 0 | 11-08-2010 06:33 AM |
What does PTHD Native have over PTHD 9 running Natively? | acmost | Pro Tools TDM Systems (Mac) | 6 | 11-07-2010 12:06 PM |
Thoughts on a build.... | Sixstringer7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-29-2010 04:07 PM |
