#21
Re: Heat vs VCC
Perhaps you should learn from his example.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#22
Re: Heat vs VCC
Chris, which version of vcc do you have (do a get info if you can). they weren't real good at updating the user base on their bugfix builds. I stumbled across one that made it pretty solid on my end. Maybe you have one of the before last builds?
I know its maddening. I'm still trying to get EA 8 to play my 7.4 sessions without kernel panicking my machine. i really hope stability and backwards compatibility are on the to do list for avid. Quote:
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
#23
Re: Heat vs VCC
Phoenix, which I really like. Using HEAT and PHOENIX on some mixes is pretty impressive. JMHO. |
#24
Re: Heat vs VCC
I believe the second beta release! the first wouldn't work period! i downloaded the second beta 2-3 days later, the second works for a while then the GUI freezes on the screen. pt still running, but can't do much and have to force quit. Not at studio so can't confirm exact version. Since then the beta has not been available due to maintenance. Chris
#25
Re: Heat vs VCC
Steven himself has said that they'd always intended to pull the public beta at a particular time so that they could concentrate "exclusively" on the final release, and that's the stage they're at now. They're absolute perfectionists, and they're following their course as planned. The rare crashes, which all betas experience, are being ironed out.
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
Heat? or Something Like it? | Numi | Pro Tools 9 | 24 | 06-11-2011 06:13 PM |
Something like Heat for LE? | DonaldM | Tips & Tricks | 15 | 02-04-2011 02:20 PM |
Can I use heat in PT HD 9 with a 003? | evertonlouvize | Pro Tools 9 | 11 | 01-21-2011 09:19 PM |
HEAT and PT 9 non-HD | chicken | Pro Tools 9 | 1 | 11-10-2010 06:43 AM |
