Old 10-07-2005, 05:36 AM
George Ware George Ware is offline
Default New URS Compressors
URS 1970 Compressor
High Res 48 bit "Double Precision" processing
The URS 1970 Classic Console Compressor digitally recreates a popular 1970's British Console Buss Comprerssor Limiter.
The URS 1970’s Classic Console Compressor features digital recreation of transformer input and diode bridge gain reduction amplifier characterics.
Smooth and warm!
The URS Classic Console Compressors TDM versions feature Hi Resolution 48-bit TDM and 64-bit RTAS
"Double Precision" processing for increased clarity, headroom and unparalleled gain reduction. Hi Resolution "Double Precision" processing helps to avoid internal clipping in the Digital Domain.
Independent Compressor and Limiter sections
The Compressor and Limiter sections are totally independent of each other. Both feature separate variable Attack, Release and Threshold controls.
Built in Internal Side Chain Filtering
The Internal Side Chain High and Low Pass Filters fine tune how narrow or "Broad Band" the URS Classic Console Compressor will affect the program material. Both Filters completely overlap to dial in problem frequencies.
Listen Key
The Listen Key is after the Filters section. The Listen Key allows you to monitor the signal being sent to the Gain Reduction detection circuit.
Signal Flow explained
The URS Classic Console Compressors signal flow inserts the Gain Makeup control before the final Limiter. This is the secret to how hard you can hit the final "Brick Wall" Limiter. The URS Classic Console Compressors utilize Feed-back gain sensing. Feed-back gain sensing gives Compression and Limiting a servo type of control. See the detailed signal flow diagram below.
Classic Sound with Modern Features
The URS Classic Console Compressor adds other powerful modern features such as totally variable Compression Ratios, Attack and Release times.
Two Different Plug-ins
Two different URS 1970 Classic Console Compressor plug-ins are included in this bundle.
The 1970 version includes :
• Compressor/ Limiter / Side Chain version
• Compressor only version
The 1970 Compressor /Limiter / Side chain version has a "Brick Wall Limiter to smooth out the most difficult musical tracks. The 1970 Compressor /Limiter / Side chain version is well suited for Drum Sub Groups, Aux sends (TDM versions) and especially on the Mix Bus.
The 1970 Compressor only version is 3x more DSP efficient. The Compressor only version is very well suited on general instruments, such as vocals, guitars, bass and individual drums. The 1970 Compressor Only version will act as a Limiter when the ratio is set at 10:1 and above.
URS 1980 Compressor
The URS 1980 Classic Console Compressor digitally recreates a popular 1980's British Console Buss Compressor.
The URS 1980 Classic Console Compressor features digital recreation of the IC input and voltage controlled gain reduction amplifier (VCA) characteristics.
Snappy and aggressive!
Built in Internal Side Chain Filtering Listen Key
Listen Key
Two different URS 1980 Classic Console Compressor plug-ins are included in this bundle.
The 1980 version includes :
The 1980 Compressor /Limiter / Side chain version has a modern "Brick Wall Limiter that was not found on the vintage unit. The 1980 Compressor /Limiter / Side chain version is also well suited for drum Sub groups, Aux sends (TDM versions) and highly recommended especially on the Mix Bus.
The 1980 Compressor only version is also 3x more DSP efficient. The 1980 Compressor Only version will act as a Limiter when the ratio is set at 10:1 and above.
http://www.ursplugins.com/
George Ware
Old 10-08-2005, 05:30 AM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
Default Re: New URS Compressors
FINALLY!!!!!!!!!!!!!!! You guys rock! Thank you for bringing them out.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Compressors in PT Wango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-03-2009 12:20 PM
compressors Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-28-2006 11:52 AM
URS Compressors vs UAD Compressors thejones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2005 09:54 AM
Compressors from URS!!!! mindnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2005 02:41 PM
what compressors do you use for vox? shaun thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 09-06-2003 07:43 PM
