Where is the Disable Fader Movement During Playback feature for Control 24?
I posted this this thread (here it is for reference: http://duc.avid.com/showthread.php?t=287397) in the Control/C|24 forum and the only response I got was for the C|24 - not a Control | 24. After I replied no one else has chimed in - thought I would try here (this forum seems to be a lot more active and budding with information than the other).
Cheers! Ron
ron [k] Musician/Programmer/Engineer/Remixer System: PT HD v8.0.1cs2/PT 9 HD3 Accel, 96 I/O, 96i I/O, Control |24, Midi I/O, Sync I/O ___________________________ http://myspace.com/ronk http://ron-k.net/studio.html http://facebook.com/ron.k.music |
Re: Where is the Disable Fader Movement During Playback feature for Control 24?
Hi Ron,
There's no feature on the control 24 all you can do is put into master fader made! Chris
Thanks Chris!
Your suggestions is a viable workaround! But I really thought I recalled having seen a check box somewhere in the preferences a few versions ago that would disable such? Maybe it's the old age of being 31 setting in Ron
workaround:
Make a bank of EMPTY midi tracks. Set them to faders at 0 (- inf). When you want to playback without any fader movement, bank your control surface to your bank of midi tracks. Use this technique in conjunction with Massey's "Listen" plugin
--Jeremy |
Good suggestions but I wanted to add that long ago this did exist - DTS told me to use it at a client's who's G4 wouldn't let us bounce a pretty simple pop tune thing. This was 5.3.1, I believe, back in 2003-2004. 001 LE system. Not sure when it disappeared!
... but does it help the chorus? |
There was a preference in the automation preference section for disabling moving faders on the screen. However, this is no longer available. This preference never affected control surface faders.
MP4 Playback Jumpy with image movement | Old School Audio Guy | Post - Surround - Video | 3 | 01-04-2013 11:00 PM |
Where is the Disable Fader Movement...feature? | The Missile Silo | ICON & C|24 | 3 | 12-22-2010 06:48 AM |
Control 24 - fader mm movement | IntelDoc | ICON & C|24 | 8 | 07-02-2009 10:06 AM |
Fader movement after automation written | Siegfried Meier | Pro Tools TDM Systems (Mac) | 8 | 01-27-2005 05:24 PM |
strange fader movement when recording midi | forthecause | ProControl, Control|24, Command|8 | 1 | 12-18-2004 07:07 PM |
