Old 03-17-2009, 08:02 PM
Shawn Simpson Shawn Simpson is offline
Default Re: how to calibrate with a voltmeter , my 888s
Audio signal by its very nature is an alternating current; there is a positive and negative phase to each cycle. I use a Fluke 87 with a cable just like Craig described. I actually have about a dozen or so sets of leads (bananas are cheap) with male and female xlr's, TRS, TT, military, and a couple with plane old terminal screw or alligator clips. Certainly makes things go much smoother when you can just plug right in.
Old 03-17-2009, 08:33 PM
gould gould is offline
well i got a meter,i put it on V-20, my outputs so far on the 888 are output 1= 0.98 output 3= 0.98 output 8 = 0.95 I dont have 2000m on mine. i hope i have it on the right setting. sounds like there low. suppose to be 1.23 isnt it.
Old 03-18-2009, 10:54 AM
Craig F Craig F is offline
what meter did you get?
Thank you,
Craig
Old 03-18-2009, 12:06 PM
one from walmart, forgot what its called, just a multimeter
Old 03-18-2009, 12:17 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Yup you are correct. My apologies. It is AC. I just talked to the Cheif Tech here at the studio... he suggested getting something like a behringer cable tester. It has a tone generator in it that will do +4dBu and -10dBV and from his experiences he said it's pretty accurate. It generates tone to all it's outputs so that might be the best way to go... plus you'll have a quick and easy cable tester. *shrug*.
Old 03-18-2009, 12:29 PM
Old 03-18-2009, 01:57 PM
NuBus NuBus is offline
Here's How Digi Suggests How to Calibrate your 888
http://www.digidesign.com/index.cfm?...&categoryid=34
Old 09-01-2009, 01:22 PM
Felix Felix is offline
well, this still doesn't really answer the question good enough as I'm not too confident about it.
I've been thinking I can use my Lucid DA convertor as a 0 dBu test tone (using a test tone generator off the laptop going digital into the Lucid and adjust the output of the Lucid until it reads 0 dBu for it's output).
I then calibrate my Rosetta AD to have that tone = -14 dbFS.
This seems adequate as it shows up on my mixer as 0 dBu.
Then I use the Rosetta AD in calibration mode as a VU meter to calibrate the outputs of the 888|24. so a -14 reading can be considered as 0 dBu.
However, when I run the 888 output into the input to set the input to -14, i can't get the trim to get past around -15.2 . i gotta be doing something wrong here. (the inputs are set to balanced line input)
the Digidesign web page states:
4. Using an AC Voltmeter, measure across pins 2 & 3 of the output XLR (or across the tip and ring of a TRS plug). Adjust the output trim pot until the voltage reads 1.228V (for +4dBu) or .316V (for -10dBV)
what I need to know is what should the meter be set to?
my meter has either 200 or 600 ACV settings. if these won't work, then what settings does a Multimeter need to be used in step 4? any suggestions on a Multimeter to get that can do this that isn't well over $100. as cheap as can be in order to just get this task accomplished.
Old 09-01-2009, 02:32 PM
Rail Jon Rogut Rail Jon Rogut is offline
http://www.amazon.com/Fluke-115-Comp.../dp/B000OCFFMW
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-01-2009, 07:09 PM
Originally Posted by Rail Jon Rogut View Post
nice deal
Thank you,
Craig
Calibrating w/ voltmeter Chris_in_MTL General Discussion 2 09-27-2004 05:41 PM
001 vs 888s Joz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-06-2002 05:27 PM
Help with Apogee and multiple 888s Jim Roberts Pro Tools TDM Systems (Mac) 3 03-05-2001 04:40 PM
Should I get 888s or the new Steinberg 8i/o converters?? gsdrill General Discussion 3 07-17-2000 07:20 PM
PT loses outputs from multiple 888s babyseal Pro Tools TDM Systems (Mac) 0 05-13-2000 01:06 PM
