Old 04-25-2017, 02:25 PM
oortone oortone is offline
Default Does twin ethernet adapters work
Hello.
I'm considering buying a second Artist Mix and since I will then need a second Ethernet port I'm considering a usb-to-ethernet hub with two ethernet ports, like this:
https://www.startech.com/Networking-...rt~USB32000SPT
Will this work? Or do I need a router/switch for some obscure network reasons?
EDIT (many years later): Twin Adapters like the one listed does not work well. Switch or router is needed for more than one connection.
Old 04-25-2017, 03:40 PM
Default Re: Does twin ethernet adapters work
I run a WiFi router here that also acts as a hub. Not only do I have Artist MIX and Transport connected(and both work dandy), its a 5GHz dual-band that also allows me to run PT[Control on my iPad(2nd Gen) for more(and remote) control If you are counting pennies, a simple ethernet switch will handle multiple Artist units(IIRC, you can run up to 4 Artist Mix units for 32 faders)
Old 04-28-2017, 01:15 PM
EddieJones's Avatar
Use a cheap router or switch.
Old 05-06-2017, 11:37 PM
Thanks for the help.
What will the difference in funcionality be if I chose a switch instead of a router?
Old 05-07-2017, 12:18 PM
EddieJones's Avatar
A router has a DHCP server in it and a WAN port/firewall to connect to the internet. A switch just passes data.
Old 05-18-2017, 01:09 AM
Thanks, but how does this affect functionality for my Artist Mix/Computer?
Are there any differences in how I setup the system in preferences, differences in performance and things like that?
Which do you recommend for a user with a limited system only used from time to time. I prefer things to be as easy as possible and I only need to connect ethernet to the Artist units, nothing else.
Old 05-18-2017, 08:53 AM
EddieJones's Avatar
If you are not connecting to the internet and only connecting EUCON surfaces on the network, the best way is with a switch. If you only have one surface, a direct cable between that and the computer is even better. With this method you can leave all settings on the surface and computer default too.
Old 05-18-2017, 10:06 AM
As mentioned in the thread start this was if I would buy a second Artist Mix.
I do use Wifi for internet but ethernet only for the Artist Series. So which would be the best in this case if I prefer to change as few settings as possible when the Artist units are connected?
Old 05-18-2017, 10:08 AM
simonjewel's Avatar
simonjewel simonjewel is offline
I plug both of my units straight into the Macs Ethernet ports ... no problems thus far unless I use wifi to connect to the net
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11.
Old 05-18-2017, 10:10 AM
EddieJones's Avatar
You could plug them into the router where your wifi is, there should be 4 ports on it.
Eucontrol 3.5 - the ethernet solution when wireless WON'T WORK nlaflamme Avid S1, S3, Dock and Control App 1 03-19-2017 09:05 PM
Does Eucon actually work with a usb/ethernet adaptor? robertg Artist Series 1 07-23-2015 11:36 PM
Apple ethernet adapters Thunderbolt vs USB tams Artist Series 1 05-04-2015 04:25 AM
Will Control 24 work with USB to ethernet adapter ? VIKING ICON & C|24 3 08-30-2009 03:13 PM
C24 wont work. No ethernet drivers. juzbag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2003 01:37 AM
