What is this little triangle in my edit window??
I've been using PT for at least five years and I have never seen this before:
A tiny triangle at the bottom of an audio track in the middle of the song. Almost like a marker symbol, but without the color. A little embarrasing, as it probaly is something very basic.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: What is this little triangle in my edit window??
it is the icon for an audio track. the midi and aux tracks have different icons.
or maybe not, i'm not sure i understand which icon you speak of when you say "in the middle of the song"..
=j= |
Sounds like you placed a synch marker in the region.
Rail
Thanks Rail.
I dont have my manual right now, what is a sync marker? How did I place it there, and how do I delete it? (It cant be selected, it seems.)
Select the clip and choose "remove sync point" form the Edit menu (or <Command>,)
Glen West |
Thank you guys.
I found it in the ref.guide. Apparently I have accidentaly hit downarrow wich sets a sync point. I hardly ever use time code sync and such, so I didn't know about it.
The down arrow doesn't set a sync point.. it marks the beginning of a selection.. Command+, toggles a synch point at the current cursor position in the region.
Rail
Mix Window Freezes but Edit Window works fine. | wwicklund | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2022 10:57 AM |
Session Data/Mix Window/Edit Window gone?? | 440Hz | macOS | 1 | 08-02-2011 03:44 PM |
Tracks Showing in Mix window but not Edit window | midi sordino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-23-2010 09:43 PM |
Cannot change EDIT MODE in edit window | Xavior | Pro Tools M-Powered (Mac) | 2 | 05-24-2007 12:51 AM |
How do you scroll the window with the audio on edit window? | fsilano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 09:53 AM |
