  #41
Old 03-22-2023, 11:17 PM
Sugarnutz Sugarnutz is offline
Default Re: Searching for a piano VI
I don’t play but for visiting pianists I have a Kawaii VPC1 with a choice of Ivory II American Grand, Keyscape, an old Bosendorfer PM290 library that runs under Kontakt (I know). If need be I can drag out the Gigastudio PC and hook you up with “The Old Lady” by Post or the Gigapiano, no problem at all. The old Gigastudio PC also has a Pro Tools 8 HD4 TDM rig in it and although I haven’t done it I think Ivory II will run on it, don’t quote me but I’m pretty sure Synthology supports several older OS. That’s either Win XP or my old Mac Pro running Mavericks.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #42
Old 03-23-2023, 09:11 AM
FunkzzaJ FunkzzaJ is offline
Originally Posted by musicman691 View Post
Looking for a new piano VI. I already have a couple of the NI Kontakt ones, the Model D and Austrian Grands for UVI Falcon. Want a decent Steinway D and B; anything else would be gravy. I want to stay away from any Kontakt-based libs so that leaves out the Galaxy Instruments wares. Also because I'm on the hairy edge of working with UVI Falcon and my ancient OSX 10.13.6 the VI Labs stuff is a low priority (and they have a D but no B). Further I'd like to stay with one developer if possible. That leaves the stuff from Synthogy (Ivory) which are sample based and Modarrt (Pianoteq) which are modeled.
I like demos as much as possible and Ivory doesn't do that. Pianoteq does so I'm working with that. That being said what do people here like? Any problems with either? Are there other piano vi's out there I'm missing?
check soundpaint. 127 velocity levels. free 1928 steinway. paid D, C7 and more. low price.
/T
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
  #43
Old 03-23-2023, 09:45 AM
JFreak's Avatar
JFreak JFreak is offline
MIDI has 128 velocity levels (0-127) but it has absolutely zero correlation to how many velocity levels has been sampled. Even single-sample VI can say full 128 velocities, but high-end instruments (such as Ivory) have more than one sample for each note. In case of Ivory it is 18 samples.
Janne
  #44
Old 03-23-2023, 09:47 AM
got it J
/T
- but until then -
  #45
Old 03-23-2023, 10:46 AM
Eric Lambert's Avatar
The Mayans when we mention "0" as a numeric value:
  #46
Old 03-23-2023, 10:53 AM
JFreak's Avatar
Well it is relatively new invention. AD 773 or something. And they say it is basis of mathemathics...
Janne
  #47
Old 03-23-2023, 10:56 AM
JFreak's Avatar
With that said, I would like to see keyboards with another one next to zero. Sometimes when you are doing binary it is cumbersome to type ones and zeroes on different sides of the keyboard. Would be so convenient to have 0 and 1 right next to each other. Or putting zero to the left if two ones causes too much confusion. But enough of this off-topic.
Janne
  #48
Old 03-23-2023, 11:21 AM
You could always use the numpad
Jack
QAPLA!
  #49
Old 03-23-2023, 11:25 AM
/T
I don't see any system requirements on the site.
Jack
QAPLA!
  #50
Old 03-23-2023, 11:36 AM
JFreak's Avatar
Maybe it is so cheap it does not require anything?
Janne
Searching DUC nhwinni Pro Tools 9 1 10-04-2011 04:32 PM
looking for a Piano-Bar for a grand piano teacherman General Discussion 2 01-09-2007 11:36 AM
looking for a Piano-Bar for a grand piano teacherman General Discussion 0 01-09-2007 06:48 AM
searching sabages General Discussion 2 11-14-2005 04:40 PM
Searching the DUC rusmooth General Discussion 0 06-22-2001 07:29 AM
