Key Command question
If you hit the Minus (-) key with the cursor on a single audio track, it displays audio volume automation for that track. This is good. But if you hit the Minus (-) key with the cursor on a single MIDI track (in clips view), instead of getting the audio volume display, you get the notes view. This is so useless. Is there any way to get a key command for a single MIDI track to display volume automation?
Even the command for all tracks is the same. Hit Option & Minus (-) key and you get audio volume view on all audio tracks, but not on all MIDI tracks. You still get the notes view. Any solution to this appreciated...thx. |
Re: Key Command question
Yes this is super lame, agreed. I have found the best way to navigate to inst track volume automation is to control-cmmnd click on the volume readout of the track and the audio volume will pop up. hitting the - twice will then return it to clips view.
Thanks for that tip, it really helps!
D command CF question | uno1234 | ICON & C|24 | 7 | 10-27-2010 03:26 AM |
Command 8 Question | Wyn | ProControl, Control|24, Command|8 | 0 | 06-28-2010 05:31 PM |
Key command question | Don Geppert | Pro Tools TDM Systems (Mac) | 2 | 10-30-2005 10:48 AM |
Command question | Drive d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-23-2003 04:14 PM |
