Multiple Flatpanel Displays
Has anyone had any luck running more than one flatpanel on a newer G4? I'm running an SGI 1600 Flatpanel along with an Apple Cinema display using one AGP card and a promac card for the SGI on the PCI bus.. of course, this is giving me PCI bursts and errors... Does anyone know of a video card for the Mac that can run two seperate spanning flat panels?
Thanks. |
Re: Multiple Flatpanel Displays
I am using the Appian Jeronimo J2000 AGP Dual Card and tow 18.1" NEC multisync LCD monitors.
------------------ Dan Matthews InSight Sound Recording
Dan Matthews InSight Sound Recording Loveland, CO (970) 663-1650 InSight Sound Web Page |
I, too am running the Appian Jeronimo AGP with 2 IBM 18" TFT's... Pretty swanky.
-dg |
I guess my problem is that the SGI and the Apple Cinema displays both have some type of DVI or digital connector, while I would imagine the ones that you guys are using have regular analog connectors?
The connection between the video card (most likely the Formac card) and the SGI monitor is a proprietary interface. I believe this interface is only used on the SGI monitor, hence the limited number of cards that directly support the SGI display...
I believe the Apple Cinema display uses the DVI standard... I don't think the PCI bus cares much as to the interface between the video card and the monitor, but the errors are more likely I/O errors on how two video cards are accessing the PCI bus, or maybe EMI interference between the cards.... I ran a Twin Turbo and Rage card PCI cards at the same time on 9600, and didn't have any errors with 2 cards running.. Now, I would like to reduce to one PCI card for dual monitors. I don't think anyone makes a PCI video card with dual monitor support (for Mac 9600's)... If anyone knows of one, please send me mail... thanks..... |
I am running a 9600/G3-400 with two SGI 1600sw panels on two ProFormance 3 cards. Also a DC-30 capture card, a 3940U2W scsi card, and a 13 slot expansion chassis with Mix core, 3 Mix farms and 3 Merle farms. It's truly a rockin' big setup. I LOVE IT!!
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Multiple displays with Pro Tools | sarodplayer | Pro Tools TDM Systems (Mac) | 15 | 10-26-2007 04:09 PM |
HELP...setup for multiple displays!!! | Javier Santiago | Post - Surround - Video | 9 | 09-18-2007 09:12 AM |
Multiple displays | stevegalante | Pro Tools TDM Systems (Mac) | 13 | 07-03-2006 09:18 AM |
support for multiple vid displays? | Chuck1073 | Digidesign Hardware & Software | 1 | 12-17-2000 09:16 AM |
Multiple Monitors, SEPARATE displays | sadsongs | General Discussion | 5 | 10-25-1998 09:02 PM |
