Old 04-13-2006, 05:48 AM
yRRe yRRe is offline
Default how to get PT send start command at any position
i have an good old yamaha rx11 drumcomputer atached to my mbox2. everything is set (audio-midi-konfig, recieve chanel and so on) and working fine. i can send midi from rx11 to PT and the other way round.
also, when i hit play in PT the rx11 starts playing, too.
problem is, that PT only sends a start command at position 0:00:00.. hitting play at any other position it sends a !continue! command which causes the rx11 simply to continue the beat where i hit stop (in PT) before. that's totally crap when i want to tune in at any point of my track to try some extra tunes on other instruments while the beat is totally offbeat. i hope you know what i mean..
so how can i setup PT to always send a start command?
greets
yRRe
Old 04-21-2006, 05:18 PM
Default nobody?
Old 04-23-2006, 06:06 AM
Lapick Lapick is offline
Default Re: how to get PT send start command at any positi
I'm not very familiar with the RX11 but I know it has various modes for receiving external midi. It's possible that the RX11 is not correctly interpreting the midi data. I say that because I've been using MMC/MTC via PT to control and sync an external software sequencer all along and have never had a similar problem. I took a quick look through the manual and the menus and I can't actually find any way to tell PT not to transmit the song position pointers.
cursor return to start position liberccxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-12-2023 11:15 AM
A Silly Question ... Go To Position - Key Command Zergei Tips & Tricks 2 09-01-2013 05:42 AM
How to get counter to reset to start position Digitalkidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-03-2009 11:42 PM
Cursor back to start position thenchel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-30-2006 05:28 PM
Cursor start position moves after playback... WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-12-2005 10:26 PM
