Old 03-18-2020, 06:58 AM
crandallwarren crandallwarren is offline
Default Lock song to new tempo with beat anchors?
Hey All,
I feel like there is a way to do this, but I can't quite remember the step by step.
Here's the situation:
1) I have a song that wasn't recorded to a click. We're hoping to do some VI orchestration. So, I went through and mapped the tempo map manually by putting "identify beat" markers on the 1 and 3.
2) For the most part, the tempo in the original track is pretty steady, but there's one 2 bar section where it yo-yo's really bad and it really messes with the string orchestration we've got going.
So here's what I'm trying to do:
By setting the tracks to "ticks" and using Elastic Audio, is there a way to use the beat anchors I've put in to conform that 2 bar section to a fixed tempo?
I've tried using the tempo operations to insert a tempo in the timeline across that section. But it doesn't quite seem to be doing what I want to do.
Because the function of the beat markers is to adjust the tempo-- it seems to behave weirdly when trying to do this.
Thank you!
C.
Old 03-18-2020, 01:46 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Lock song to new tempo with beat anchors?
Sure you can, I do it all the time. Just go to the beginning of the bar, hit the + next to Tempo to the left of the timeline, and type in the new tempo. Then you can delete any tempo markers after that one and the track should conform to the new tempo up to the point where a different tempo marker exists. As you mentioned, you have to be in Tick Timebase (and Elastic Audio enabled, obviously).
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Eleven Rack standalone Editor: Can it "lock hardware tempo to session tempo"? ToddnTodd Eleven Rack 17 02-02-2014 02:29 AM
Using tempo match or beat detective for DJ song mix stereofidelic Pro Tools 10 22 01-15-2014 12:56 PM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
Can I lock an audio region to a particular beat (tempo changes)? apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-08-2002 08:07 AM
Can I lock an audio region to a particular beat (tempo changes)? apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-06-2002 05:24 AM
