Old 01-05-2011, 03:24 PM
colinmansfield colinmansfield is offline
Default Re: Converting Stereo to Mono
Originally Posted by dunego View Post
Yep but it´s still double processing 2 mono files. Plugins will have to be stereo, double processing power. BTW a maybe little off topic here but a freeze feature in PT would be nice too. What´s the deal with it, maybe freezing tracks doesn't sounds 'professional' ?
If I were converting stereo tracks to mono I wouldn't want to muddy the waters by throwing plugins at the stream...
Colin Mansfield
Bandcamp
Soundcloud
Old 12-28-2022, 09:32 AM
K Roche's Avatar
K Roche K Roche is offline
Well the old adage "Ya don't know what you don't know" comes to mind
It's right there when you right click on the track name
Top of second group down
_______________
Freeze
Commit
Bounce
_____________
And BTW one reason (old or new) for dual mono tracks is they can be processed and panned completely separately giving you a bit more precise control Especally in audio recording and mixing
System :
Enjoy the Journey
.... Kev...
Old 12-28-2022, 09:45 AM
The real reason for PT getting stereo files out of mono material on import is that some stupid DAWs (don't want to start calling names) always export the master output channel width. THAT is stupid.
Old 12-28-2022, 10:34 AM
Sardi Sardi is offline
_______________
Freeze
Commit
Bounce
_____________
They didn’t know because they posted their response 4 years before the feature was added.
What an odd thread bump.
Old 12-28-2022, 07:58 PM
Top Jimmy's Avatar
And to merge the two into one…
1) Split stereo to two mono.
2) Trim back the right region and drag it on top of the left region.
3) Add a block crossfade from start to end of regions.
4) Consolidate.
5) Delete empty track.
James Cadwallader
Old 12-29-2022, 05:34 AM
K Roche's Avatar
Humm my bad,,, wonder why it popped up in new posts ?
System :
Enjoy the Journey
.... Kev...
Old 05-20-2023, 07:37 AM
soundstudent soundstudent is offline
thought i would jump on this post as its in the same subject matter. I have managed to record vocals in stereo and when i zoom in they are not identical so i cant just split to mono and hide and make inactive the excess tracks unfortunately. can i consolidate the left and right and pull it all together. i honestly have no idea how i managed it.... total rookie here really even though ive done the 101 and 110 !!
tia.
Old 05-20-2023, 08:26 AM
I did see the process detailed above but that hasnt worked
Old 05-20-2023, 10:55 AM
Ben Jenssen's Avatar
Hi Soundstudent.
I suggest you start a new thread. Would be much tidier, and people wouldn't have to relate to other replies that are up to 14 yrs old.
Please, also try to be more specific about what you have and what you're trying to achieve. Was the stereo vocal recorded with two mics? With a stereo effect? Which' process above' didn't work?
Can't you just pan L&R to the center? Do you hear a difference if you try? Do you know how to flip the phase of one side to check for so-called 'nulling'?
Old 05-21-2023, 12:29 AM
Hi Ben
Thanks for your response and apologies for being so vague!
My head is really spinning with this. I recorded a quartet with close mics but they were all in the same live room at the same time with no isolation so lots of bleed (they had never been in a studio before so isolating was out of the question). In error, I set up the tracks in stereo however when I solo'd each track it sounds like the left and right are two different singers??? splitting to mono has worked but I can't get my head round how that could even have happened in the first place?? I'll take the issue to my lecturer, maybe he can explain it.
Converting Stereo to Mono audio trax DonaldM Tips & Tricks 12 11-10-2009 06:00 AM
converting stereo tracks to mono bigboi78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-23-2005 12:42 PM
converting a mono track to stereo cdp2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-07-2004 06:38 AM
Need help converting a stereo track to mono Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2004 09:30 AM
Converting stereo to mono in PT Lord Humungous 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-20-2003 10:11 PM
