Old 10-30-2003, 03:25 PM
daustin777 daustin777 is offline
Default Acid to PT6 session convertor
Does anyone know of a conversion app that will input an Acid file and output a PT session file?
David Austin
David Austin
p4 3ghz, PT 6.4, XP, Digi002r, AMT8, Mackie Control
Old 10-30-2003, 08:06 PM
pk_hat pk_hat is offline
Default Re: Acid to PT6 session convertor
nope.
do you mean an Acid session or an 'Acidized' audio file or loop? As with any other app, you can render your Acid tracks as wav/aif files and line them up in a ProTools session at the same tempo. You can't simply convert an actual Acid session into a PT session and to my knowledge, this applies to any two pieces of software.
www.myspace.com/krou
Old 10-31-2003, 12:53 AM
Yes!
It is technically possible- just a simple conversion that an application could do. I'm suprised nothing like this exists. Wouldn't it be great to be able to take a Nuendo, Cubase, Logic, Sonar session and convert it to a PT session? It is commonplace amoung other media formats (graphics, layout apps, sound files, video). From a programmers view it wouldn't be too difficult from a user's view it would be a worthy tool. If only I could get a Digi and ACID SDK.
Yep. Thats what I do.
David Austin
Old 10-31-2003, 02:42 AM
TCDet TCDet is offline
Talk to the Acid folks to allow OMF. This works for other non Digidesign software exports to be opened into ProTools.
" DigiTranslator 2.0 is a OMF/AAF Interchange utility, delivering reliable, accurate conversion and exchange of OMF and AAF (Advanced Authoring Format) files directly through the Pro Tools application. With DigiTranslator 2.0, the complex process of file interchange is made simple and dependable."
Old 10-31-2003, 10:49 AM
Thanks for the info.
David Austin
Help getting an ACID Pro 6 session into Pro Tools! ChrisWhite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-15-2008 07:57 PM
Rex and ACID WAV files don't sync to session tempo blkdog7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2008 07:56 PM
442 as a d/a convertor Chuck1073 Digidesign Hardware & Software 2 08-10-2006 11:21 AM
Acid session into Pro Tools? joejackson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-27-2004 06:47 AM
New convertor, how much better really? marchhare 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-27-2002 12:27 AM
