Western Digital External Drive
I got a 200GB Western Digital External Firewire/USB Drive.
Will I be able to run sessions on it? Is it easy to run a session on Mac Pro Tools and then mount on PC Pro Tools and jump back and forth? How do you "mount" a hard drive? |
Re: Western Digital External Drive
Just got the 120gb myself. You don't really have to mount anything, just install the software once on the PC. On the Mac, I don't think there's anything to do. After that, it's plug-and-play, so you can even unplug the drive (Safe Remove in XP, drop in Trash can on Mac) and replug it in the other computer. Sessions are totally portable, although I was unable to load sessions directly from the drive at my friend's place with his 002 (I have a 001). After copying the files on his own FW drive, he could load the session.
But yeah, you can record directly to the drive, although I use FW for backup purposes mostly, but I've recorded direct, worked just fine.
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
If your FW drive utilizes the Oxford 911 chipset you can run PT sessions on it, otherwise it's only for storage.
FWIW, this firewire docking system will run PT sessions, is totally expandable and accepts any standard ATA drive that is Protools compatible. the dock cost is around $90, including one inner tray, which you put any drive. add'linner trays are $25 each. You can easily see the infinite expandability of this system, not needing to buy mor ethan an inner tray. Drives are of course hot swappable. It is silent, efficient, universal AC powered, and extremely economical. Hope this is helpful. |
I cant format for cross platform!!
OSX and Win XP I have tried partitioning on both the Mac and PC but when I bring it to the srcond computer....it wont read it |
You must format the drive on a windows machine for it to be cross platform. Whiel the Mac can read a windows drive, windows cannot read a mac drive.
But I think in osx that changed...no more fat 32
Im thinking of getting a External Firewire Drive, but would really need to go across a few platforms! |
Will a western digital external drive work? | rofa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 07-28-2009 12:17 AM |
Western Digital External HDD | RedLightNation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-21-2007 08:19 PM |
Western Digital My Book 500G External | pinstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-28-2007 01:41 PM |
Is Western Digital external 120 GB FW drive suitable for PT ? | Dale-c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 02-19-2003 07:12 PM |
Is Western Digital external 120 GB FW drive suitable for PT ? | unclestanky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-19-2003 12:06 AM |
