just joined the club
got in my HDN and 16x16 today. got to get a project finished up before i can take the down time to get it installed, but looking foward into joining in the fun!!! this forum section has been a bit boring so maybe i can get tom and aaron all worked up
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Re: just joined the club
Welcome to the club!!!
Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
Thanks, just to save myself the research, i coming from an RME fireface and Lynx Aurora.
on the 16x16, are the digital i/o mirrored from 1-2 or anything silly, or can i assign them however i want. speaking for the spidf and aes specifically. would like to put my eleven rack on the spidf and api a2d on the aes. debating on selling the lynx and get an omni. could use the 2 pre's on there since selling the FF800 and all my other pre's are colored, and i use a central station for monitoring, or getting the LTHD card for the lynx since it has had a firmware update and compatible with the new HD series.....hhhmmmm ....to many decisions!!!
As for your first question, the answer is yes and no. The digital I/O can be assigned independently, but the problem is that it's either/or. You can have the AES, or the Spidf, but not both at one time. They basically both fall under "Digital I/O" and you would choose which one you're using in the hardware preferences.
Also, keep in mind that the 16x16 is a max of, well, 16in, 16 out. You can use any combination of 16, whether digital or analog. So you could use 8 analog, 8 channels adat. Or 12 channels analog, 2 channels Spidf, and 2 channels Adat, etc. That would be for the ins, and the same thing applies to the outs. But again, it's either Spidf or AES. As for the other question, I think you'll do better to sell the Lynx and the Central Station, and get the Omni. That will give you all the monitoring capabilities, more I/O of the same high quality conversion as the HD IO (both sound better than the Lynx), plus the preamps, which are actually quite good (so are the DI's). Plus, adding the Omni, you help with your Spidf/AES problem, by having another set of them (though the same issue still applies: either/or. But you could use the Spidf on the Omni, and the AES on the HD IO, or vice versa). |
Well everything is up and going.
took about 15 minutes to install the card, boot up, update firmware, and get it going, then a bit reconfiguring the I/O settings. of course took hours building new cables and then gutting and rewiring the patchbays and such.....but thats another story!!! so far so good!
What is your computer config?
in my user profile thing....
Intel I7 920 Gigabyte EX58A-UD3R 12 GB Corsair 1800 ddr3 Nvidia 9600gt lots of drives... w7 64 jumped right into mixing some fairly large sessions and running great. buffer is at 512. should get some tracking done this weekend to check that out (32 hw buffer!!!) and test out the rest of my hardware and such.
Try tracking at 64 samples or if your at 96k track at 128 samples. Good luck
Pretty great Steven. How's the buffer size workin'?
Just joined. What is going on here ? | Avidfan | Pro Tools 10 | 47 | 11-09-2011 07:42 PM |
I joined Deep Purple! (Highway Star guitar-oke) | adamqlw | Eleven Rack | 5 | 04-26-2011 05:27 AM |
Mix Club | molmaniak | General Discussion | 0 | 11-04-2008 10:39 PM |
Pro Tools LE 7.4 on Windows XP Pro SP2 Domain Joined Box | Willosy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-17-2008 04:42 PM |
I just joined the dark side. <--HP Pavilion zd8000 | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-27-2005 12:16 PM |
