Help! Tracks drop-out! Audio plays in weird places
So this is a problem I've had off and on, and it seems to have returned now that I just re-configured my hardware, adding a Rosetta 800 on an ADAT bridge.(I've had the adat bridge all along, but with an ADAT on it...) System is Mix+ TDM on a G4/933 OS9.2 PT v5.1.1. Adat bridge is now primary interface off Core card with Rosetta 800 A/D, and the 888 is in Slave mode on my Farm card. Sounds great, except...
Often when I have sessions with a lot of voices set to "Auto" (which is imperative in order to take advantage of RTAS plugs...) I will have tracks randomly go silent during playback, for no rhyme or reason. Could be any track, but almost always one with an Auto voice. If I stop and start playback, all voices resume playing. But then at any time some other voice could shut off. Sometimes when this is getting back I will also get chunks of audio playing even when they are nowhere near the current cursor point in the tune. This generally means I'm going to crash, and if this stuff is going on and I Save and Exit PT, I get a crash and have to reboot. This rarely leads to lost data, but is really, REALLY annoying! I can fix it by making all the voices assigned specifically, but then I can't use RTAS plugs, and that's just dumb. Any tips? This problem comes and goes, but seems to be "coming" right now. Thanks! - Steve |
Re: Help! Tracks drop-out! Audio plays in weird places
Just had this happening to me. The way I fixed it was to change the number of DSPs used for the mix engine. I was using 2 DSPs and I changed it to 4 DSPs. It solved the problem for me. Go to the playback engine setup and increase the number of voices/DSPs you use for the session.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
Had something similar once. It was bend pin in one of my ADAT Bridge cables.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
It may append when you have more than one copy of each audio files... Like when you import from a CD and still have the CD in the drive.
Try to "save as" to another empty disk (if possible) with copy audio, then unmount all other drive, and try again. JC |
HELP!! PT10 Latency overcompensation places odub tracks 40ms early | peteage | FireWire & USB Audio Interfaces (Win) | 0 | 09-09-2013 04:11 PM |
tracks drop out of record in 7.3 | mampam | Pro Tools TDM Systems (Mac) | 2 | 05-26-2009 11:16 AM |
003 Rack - Will not play DVD audio but plays CD audio ok | t56tr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-04-2007 07:14 PM |
7.3 creating Fade Folders in weird places??? | a2zproductions | Pro Tools TDM Systems (Win) | 4 | 01-27-2007 10:01 AM |
Inactive Instrument tracks - MIDI still plays! | gonzolagonda | Pro Tools TDM Systems (Mac) | 7 | 01-15-2007 12:52 AM |
