EQ automation disappears from LE to TDM
I'm mixing TV shows at my home studio(OSX PT6.4) using the 4 band digirack eq's out of necessity.I enable all the automation parameters in the auto add box. When i open the session on PT TDM on OS9 5.x the hi mid freq band and lo mid freq band are not automated.This blows away all the eq'ing that was done. I've performed this unfortunate bug on 2 systems. Anyone?
Re: EQ automation disappears from LE to TDM
Since you're going from a PT 6.4 system to a PT 5.xx, the plug-ins are probably not the same version. Somewhere along the way, didn't the Digirack plug-ins move to Digirack II? Probably with the switch to OSX and PT 6. So it's no surprise the automation doesn't move to the older system.
Either print your EQ'd tracks or update the other system. C'mon, get the other system up to speed. (and get rid of those [k] plug-ins. That's the only reason anyone's still using OS9/PT 5 anymore anyway ) rcm
Save early and often! (or once a day whether you need to or not...) |
LFE disappears? | melodydetective | macOS | 3 | 09-26-2012 10:45 AM |
002 'disappears' | wwittman | macOS | 3 | 05-29-2012 05:26 PM |
ProTools Disappears!?! | Vercingetorix | Eleven Rack | 4 | 05-28-2012 01:33 AM |
Panning automation disappears | aprilpsw | ICON & C|24 | 1 | 11-13-2006 04:01 PM |
sound from SC disappears in PT | tex ransom | Digidesign Hardware & Software | 0 | 08-13-1999 08:40 AM |
