Thinking about making a move...
I've been using LE 5.2 with my 001, and have had no problems. I want to try out 6.whatever, but i don't want to lose my winning streak with 5.2. I have both OS9 and OSX on my dual 1 ghz system. Is it ok to have PT 6 on OSX, and keep 5.2 on OS9 on the same machine. Will i run into any problems?
I got a fever and the only presciption is more cowbell! |
Re: Thinking about making a move...
from what i've heard of other users doing this, it works. you may want to check around, do a search for it.
I haven't had any problems with that, 5x installs in the OS9 system, and 6x installs into the OSX system. My 001 runs great in 6.4 (sadly, it runs better than my 002!) That said, I always boot up in OS9 to use 5x.
Something to think about is if you run extra plugins (beyond the stock ones bundled in the software), you'll need to get updates as the old plugins don't run in OSX. Some venders will update for free, but many charge. My advice, is if you're on a winning streak why change? Unless, there's something in 6x that is a must have for you. I upgraded soley to be able to use the reason plugin (only in 6x) so that protools will slave reason (and I use reason for everything), to get around having to output so many audio files. Then I spent a small fortune upgrading all my 'must-have' plugins (auto-tune, etc.) hope that helps, BTW--"Steeler" undoubtably one of the best heavy metal albums of all time IMO. |
If Reason is a "reason" (haha oh boy) to switch to 6x, but you really want to stay in 5x for every other reason, you should try slaving it to PT using the IAC bus. You can send PT's time code out on the IAC bus (Session Setup Menu) and bring it into Reason on the IAC bus (preferences? I think). I don't know if it is reliable as the plugin for 6x (haven't tried it) but it always worked for me in 5x. |
thinking to move from 002 Rack to 003 Factory | akhafaji | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-12-2009 07:50 AM |
Thinking of making the leap to the wintel world. | PTPerson | Pro Tools TDM Systems (Win) | 17 | 04-13-2006 12:29 PM |
Thinking of making the switch to MAC | herbyherb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-02-2006 06:23 PM |
Making "the" big move! | Dallas Taylor | Post - Surround - Video | 2 | 04-20-2004 12:28 PM |
Thinking of making a Switch | Shak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-28-2002 12:49 AM |
