Old 12-31-2011, 06:55 PM
finalcut finalcut is offline
Default Still can't find "Low Latency Monitoring" in my menu options...
I'm very sorry to persist with this question, but why do I have the "Low Latency" option available on my PC workstation at home, but not on my PC workstation at work?
Same exact program, PT10, the only difference is my box at home has a focusrite and my box at work has an 002rack.
I would love to be able to have the convenience of checking Low Latency Monitoring on my work PC like I can at home.
I always had this option on my 002rack workstation prior to installing PT10...
Can anyone help me figure out why this might be going on?
One person sugested that I make sure I have the latest 002r drivers... I think I'm using the latest drivers, the rack is linking up fine.
Thanks all!
Old 01-03-2012, 12:00 AM
Default Re: Still can't find "Low Latency Monitoring" in my menu options...
Still....
Old 01-03-2012, 06:45 AM
Stig Eliassen's Avatar
Well, in the excellent Pro Tools Reference Guide (Version 10.0, PDF document), page 95, I found the following info:
(HD Native Systems Only)
With HD Native systems, the Output page of the
I/O Setup lets you enable (or disable) Low Latency
Monitoring. It also lets you specify any
available Output path for Low Latency Monitoring.
The Output path for Low Latency Monitoring
can be of any channel width (from Mono to
7.1). Low Latency Monitoring uses Outputs 1–2
by default.
Old 01-03-2012, 07:00 AM
carlone carlone is offline
Low Latency monitoring should work with an 002. I don't remember seeing anything that states they are disabling it from that hardware.
It should be at the bottom of the OPTIONS menu (I'm sure you've already looked there). Just to be sure - you could also double check the playback engine and make sure 002 is selected.
You might also want to try posting this in the windows section where someone on a PC may be able to look.
Old 01-03-2012, 03:25 PM
DJ Hellfire DJ Hellfire is offline
I'll try to remember to take a look next time I'm in the stu. I never use LLM though, so I would have never noticed if it was missing!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 01-03-2012, 03:36 PM
southboundloco's Avatar
southboundloco southboundloco is offline
Isn't LLM suppose to be available for 3rd party interfaces only?
Pro Tools 11.2
Pro Tools 10.3.9
REAPER
MPTK2
ProFire 2626
Benchmark DAC1
Neumann KH 120 A
Avid Artist Mix
ASUS Sabertooth Z77, Intel i7-3770K CPU OC'[email protected], 32 Gigs RAM
Mac OS X 10.9.3 Mavericks
Old 01-03-2012, 04:01 PM
Not pre-Pro Tools 10. I've always had it with my 003 and my boy has with his Mbox 2 pro. But the last time I actually used it was on Pro Tools 8!
Pro Tools 2021.12
Old 01-03-2012, 04:27 PM
TOM@METRO's Avatar
It's working fine here. I've tested it with PT10 (CPTK) on 002r and 003r on Windows7 64bit.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-03-2012, 04:31 PM
Just checked here! PT10 Native, 003R, W7 x64, working fine!
Pro Tools 2021.12
Old 01-03-2012, 04:35 PM
WKG WKG is offline
Same here, no problems at all.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6
RME, Daking, Heritage, ISA, Sytek
"Low Latency Monitoring" with 3rd Party Interfaces RokVox Pro Tools 11 10 03-02-2016 12:52 AM
Can't find Sandy Bridge Dell M4700 as per "PT 11 Sys Requirements". Other options? Optofonik Pro Tools 11 1 12-12-2013 07:28 PM
Where did "Low Latency Monitoring" go? finalcut Pro Tools 10 2 12-30-2011 05:53 PM
"Low latency monitoring" which interface? samplaire Pro Tools 9 8 01-12-2011 11:59 AM
How to activate "Low Latency Monitoring" on 003+, LE 8.0.3 aidan7737 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 40 06-11-2010 08:16 PM
