Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 08-06-2010, 05:16 PM
feds2345 feds2345 is offline
Default Connect Superior Drummer to Pro Tools?
How to Connect Superior Drummer to Pro Tools?
Old 08-06-2010, 07:21 PM
Default Re: Connect Superior Drummer to Pro Tools?
Insert it in the top slot on a stereo INSTRUMENT track. Record midi hits with most any midi keyboard, trigger kit or pad(Korg NanoPad, M-Audio Trigger Finger).
Old 08-07-2010, 05:10 AM
I think Pro Tools doesnt recognize superior drummer.
Old 08-07-2010, 05:57 AM
Gemylon's Avatar
Gemylon Gemylon is offline
ProTools and Superior work together with no problem !
G
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Old 08-07-2010, 08:44 AM
I use it on almost every project I do in my studio
Old 08-07-2010, 05:14 PM
How do I route it to Pro Tools, I cant find it anywhere in the inserts.
Old 08-07-2010, 09:04 PM
Start with a stereo INSTRUMENT track. Click on the top insert slot and go to the Instruments choice. In that sub-menu, you should see DB-33, MiniGrand and Superior Drummer(as well as others). If you don't see it then the install likely was not done correctly. I would try to uninstall(put in the SD2 disk and choose the uninstaller, reboot and run the installer again. Be careful where you install(I would let it use the default destination).
Can NOT get pro tools 11 to recognise superior drummer 2.2 samfairlamb Pro Tools 11 7 08-05-2013 08:30 PM
Superior drummer 64 bit in pro tools 9 Raoul23 The Drum Room 3 07-19-2011 11:00 PM
SUPERIOR DRUMMER 2.0 in PRO TOOLS 9 Leonidas666 macOS 2 05-25-2011 01:40 PM
Superior Drummer, TD12 and Pro Tools.... JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-08-2009 06:06 AM
Superior Drummer + Pro Tools Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-17-2009 04:56 PM
