#21
Re: Print audio from Midi Track (not Instrument Track)
In addition to everything said before also make sure to have 'use first selected track' set in PT. And enable 'instruments' view in the Edit screen and see if the MIDI routing is right there. And another is to make sure the keyboard is set to do MIDI on the correct set of connections; some that have both USB and traditional 5 pin MIDI have to be specifically set for the mode to be used. It's probably something as simple as PT and the synth aren't talking on the same MIDI channel. |
#22
I did all that and did hear and record audio onto an "Audio" track. Quote:
Yes, I figured out which to designate when. This is very near the problem. When midi is set to "USB off" , that's when I can play the keyboard and trigger the external sampler. When "USB on" is selected, the Midi Track in PT plays the external sampler but a correctly routed Audio Track is not registering audio from the external sampler. Got to break for the night, thanks! |
#23
Ok, there seems to be a metering issue. The Audio Track meter doesn't register any movement when the Midi region is triggering the external sampler, it is record enabled. I seem to have got hung up on this and didn't try to actually record audio. Well, it records the audio. I get the audio from the Apollo input triggered by the midi clip in PT. That's kind of whacked of me. I thought you were supposed to be able to see meter movement when record enable was active whether or not you were actually in record mode. I did this on a test session with another external sound module, My EPS was starting to throw errors. Sorry, it gets confusing for me as I'm just starting to use external devices with a USB controller. Will have to try the EPS in the actual session. Thanks all!
#24
BTW - you have a couple of things you quoted in a previous post of yours attributed to Darryl when they are actually something I wrote. |
#25
Thanks musicman691!! Sorry for the mis-attribute, late night for me!
I went ahead and printed midi successfully just going with Audio tracks and not using any Aux. There is some strange midi behavior though and I'm not sure why or what part of the chain is causing it. Sometimes notes jam up and trigger out of time in clusters and then silence. And there seems to be inconsistent results with the same settings. Sometimes a VI on an Instrument track gets all goofy and out of tune and tempo. I shot some phone video of it. Anyway printing the external midi parts and moving on! Thanks for bearing with me and offering excellent help. |
#26
Great you got it to work. Sorry I misread your earlier post and wasted time on the audio track side of things.
#27
Thanks, I was focusing on audio as well and doing so helped me solidify those concepts.
#28
Well we're all clutching at straws trying to help you ... it's so difficult when you are trying to describe in words what is more easily conveyed in pictures.
Persevere and we'll get you there. One thing occurs to me regarding the strange MIDI behavior .... that sounds very much like a MIDI loop going on. Giving you MIDI feedback that is in concept the same as audio feedback, though the results are very different. If your MIDI track is set to accept MIDI from all MIDI inputs ... AND ... you set up that setting to enable MIDI Thru to first selected track ... then depending on how your EPS is set up you could be creating a loop. Is your EPS set up to send the MIDI it receives back out again (not using the Thru Port, but the actual MIDI Out port)? Some samplers/sequencers allow that to be set up. Another common scenario that can cause that kind of problem is if you have a keyboard with Local On enabled, so the keys trigger the sounds directly, and you have the MIDI data from the keyboard going to the computer (Pro Tools) which you've set to send the MIDI back out to the keyboard. Setting the keyboard to Local Off cures that problem. But I thnk your keyboard is a controller only? No internal sounds? Finally, if you keyboard uses both USB and MIDI connectors, is it possible that the MIDI data is goung out of both? I get the impression fom your first post that you may have the keyboard's USB connector going to the computer to let you record MIDI into Pro Tools, but you may ALS have the MIDI out of the keyboard connected directly to the EPS sampler. Is that true? If so, is the sampler also connected to the computer via USB, or by another set of MIDI ports? .... it must be to be getting MIDI from Pro Tools. In that case, the sampler would be getting the same MIDI both directly from the keyboard and from the computer via the keyboard's USB and the computer's MIDI port connections (are they on the Apollo Twin, or something else?) If the sampler is set up internally to be receiving MIDI on multiple ports and automatically merging it, then I wold expect pretty much what you are describing in terms of strange MIDI behaviour.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
#29
One of the few good things about the keyboard version of the EPS is it has polyphonic aftertouch; very few keyboards have that anymore. |
#30
I regard any of my kit from the 90s as hardly worn in yet! Yeah, poly aftertouch can be good. I have it on my 2x Roland A-80 Controllers, though you have to dig in so heavily that its unusable in as subtle a way as I would like. Unfortunately none of my Roland A-70, DX7s and DX7IID and older keyboards have poly aftertouch.
Instrument track picking up my microphone, but not my audio track. | raddster | Pro Tools 9 | 5 | 01-20-2012 04:11 PM |
How to print each MIDI track to Audio? PT9 | sylviesongs | macOS | 2 | 10-19-2011 03:07 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
Problem Converting Instrument Track to Audio Track | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2009 09:11 PM |
How does one print Midi to an audio track? | Dan M. | MIDI | 1 | 09-17-2004 08:20 AM |
