IO assignments
This problem seems to have been brought over from PT 8. When opening an older session I get a dialog that "Some paths were made inactive because they could not be assigned to existing path definitions." Fine, I have changed some IO labeling. But here's the problem...
If I reassign the "missing" paths to "No Input", when I save and re-open the session the non-existent paths come right back. Any ideas?
Dave CBS TV Distribution/On-Air PT 2019.6.0 S3 |
Re: IO assignments
Do you have "Sessions overwrite current I/O Setup when opened" checked in I/O setup?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Re: IO assignments
No. I looked at that as well.
Re: IO assignments
I'm getting that, too. But it doesn't seem to hurt anything. My workaround is to set them to unused paths. That seems to stop the annoying dialog.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Re: IO assignments
Yeah, that's what I did as well. But it just isn't right that it goes back and finds non-existent inputs that you change to "no input". And yes that dialog is super annoying.
Re: IO assignments
Any luck with this? I'm having the same problem. It's just obnoxious.
IO assignments 8.1 | Porky | Pro Tools TDM Systems (Win) | 8 | 09-08-2010 02:47 PM |
Odd output assignments | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-24-2009 05:20 PM |
Key Assignments | the | Pro Tools M-Powered (Win) | 0 | 02-18-2008 02:23 PM |
GPI Assignments | TommyT | Pro Tools TDM Systems (Mac) | 1 | 03-24-2005 08:22 AM |
soundcard assignments...... | jsmooth226 | Digidesign Hardware & Software | 0 | 10-31-2000 07:40 AM |
