Post-roll stays on input (in Auto-input)?!
Maybe I'm just "Old School", but "Auto-input" to me means when I get out of record (and roll with Post-roll) I should hear playback. Is there a way around the fact that PT's stays on input for a number of seconds during Post-roll? Was this always the case in PT's? It's just a pain if you'd like to know if your transition OUT of a record region works or not.
Tim |
Re: Post-roll stays on input (in Auto-input)?!
This seems to happen with all record modes except Destructive Punch. However, Destructive Punch is not practical for an overdub situation obviously. If you lower the DAE playback buffer in the Playback Engine you can reduce the "lag" time when you pucnch out. So, that may be the best workaround for you.
This may just be a software/hardware limitation as the software needs to switch gears and stop writing one file and start reading another file. In Destructive Punch it doesn't have this problem as it it writing into one contiguous file. But, I will see if I can get more information on this... |
I've started having this problem with PT8, I'm sure my monitoring used to switch back to playback?! Now it stays on input during post-roll. Bah!
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
Auto Input/Input Only button on 003 Console | RockGod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-16-2008 02:28 PM |
Auto Input not working with post-roll | bublabs | Pro Tools TDM Systems (Mac) | 0 | 08-02-2006 05:14 PM |
switch auto input and input only monitor with midiprotocol | mmestudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-27-2003 03:51 PM |
How to toggle between "auto input" and "input monitor" with PC?? | Camilo Orozco | ProControl, Control|24, Command|8 | 2 | 04-23-2001 01:05 PM |
