HD Video Playback-FEATURE REQUEST
FEATURE REQUEST
Please support HD Video Playback. Support of the HDV codec will allow most Post Production Professionals to get the job done and what is the issue/problem with sending the HDV signal out the Fire Wire port, the same way Protools is currently sending DV out the Fire Wire port? It is not very impressive when a Post Production Facility has to down convert it's client's HD material in order for the Audio Department to work with it and even less impressive (and extremely costly and slow) to have to sync to an HD deck for video playback during client mix reviews. |
Re: HD Video Playback-FEATURE REQUEST
I don't see this happening anytime soon...that is, HDV support.
Avid still has issues outputting HDV and still using Break out Boxes. It can't do it with a Mojo w/o a mode change, and even Avid's high end solutions (Adrenaline, Symphony, Nitris)...none of them can output HDV at full quality while in an edit mode to an external monitor. HDV is very CPU intensive (think about it..an uncompressed HD Stream is about 160MB/Sec (10bit), then compress that to 3MB/sec), and if PT already has to have an offset for DV material...wow. One HD solution is using the DVI port on the back of a Mac to an HD monitor, or to a video converter, like an AJA DVI-HDSDI converter. Or, virtual VTR and offload the HD video playback to another machine with a video capture playback board. I also hate to say it, but it's true: HDV is NOT a professional format. I have not found many - if any - facilites that will except it as a master. It is consumer at best. It is a format found on consumer/prosumer cameras, has a horribly long GOP structure, deck control is not frame accurate (let alone doing reliable assemble edits) and c'mon - has RCA jacks on it I think a less intensive CPU format - perhaps the new Pro Res, in time, may be a choice...but I do not see Digi using a FCP codec when they have their own version..DNxHD - we must take into consideration the video devices PT is designed to work with - Avid I/O. They simply can't do it.
.: michael kammes mpse .: post audio .: applications editor / workflow consultant .: michaelkammes.com .: lucidsound.com |
Call me by my real name, "Postman" |
Thanks for the addition, Richard.
Yes, the 1500 does have the often missing RS422 control and SDI spigots. I don't know where I'd be without the Miranda converter box to convert HDV to a baseband SDI source for the other decks! I also do not classify the 1500 as being in the consumer / prosumer HDV level, as far as decks go. It's the creme of the crop. You can spend several thousand dollars on a SVHS deck...doesn't mean the format is any better. I still stand by the assessment of HDV, as a format, is not a professional format. The "features" that is has in order to be affordable and available to the consumer seriously hamper it's ability to be a highly usable format in a post world.
Anyhow, playing HD video through the same system as the audio is not the best approach these days. Digi has already announced and exhibited an HD system that is integrated with Pro Tools. The downside is that it requires a dedicated computer, but that's not so bad is it?
"Ya canna change the laws of physics..." -Montgomery Scott Howard Sonnenburg Atomic Audio Ottawa, ON Canada |
Unless your system is really up to date....(Late model G5 or Intel) AND you purchased FCP....you wont even be able to view Pro Res. Plus, as I mentioned, even though the Mojo is now opened up to QT and not just Avid codecs, I can still see Avid (read: Digi) perhaps being hesitant to support Pro Res - which a direct competitor to DNxHD...plus, Pro Res is not supported on the Windows side, whereas DNxHD is.
Perhaps the Video Satellite option will help...
How about DVCProHD?
Phil |
I do not *think* DVCProHD is supported natively by QT on a Mac without an application that uses DVCProHD. For example, FCP installs this codec. If I'm right on that, then a backdoor could be to install the P2 viewer software from Panasonic. Since the HVX series of cameras rfecord in DVCProHD, that codec may allow you to pay it within a QT window. Heck, FCP Express has it as a codec...and cheaper than the full FC Studio.
Also, as I'm sure you know, DVCProHD will not play out of the 1394 port...and in my experience really slows down the performance of a PT session when it's on the timeline. REALLY slows it down.
Your video card drivers operate by means of single discrete frames. HDV is a "Long-GOP" (Group of Pictures) codec. It breaks down quickly on compositing, etc. A Simple Video Out solution, Like Kona TV does not deliver it to the physical output of the card. In other words, it doesn't play. But Final Cut will interpolate it for you and manage to get it out the card. but at a CPU price. HD demands a lot of data be pushed through pipe. Digi solutions i am sure are being considered, but getting all that data into and out of a session is likely very problematic.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
feature request for video offset via PCI output | garnoil | Post - Surround - Video | 9 | 02-08-2013 03:13 AM |
Feature request: BITC video plugin | MIKEROPHONICS | Post - Surround - Video | 6 | 10-14-2010 02:50 AM |
Major Request for Video Feature In Pro Tools | moogboy100 | Pro Tools TDM Systems (Mac) | 4 | 08-09-2005 07:44 AM |
HD 23.97 project request - Any ideas for sync/video playback/QT etc? | georgia | Post - Surround - Video | 1 | 06-21-2003 12:58 AM |
Video playback for Feature Film (FCP 3) | Ray Chung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-05-2002 05:42 PM |
