Old 06-19-2006, 07:59 PM
DTrigga DTrigga is offline
Default Mbox 1 Headphone output only to one side HELP!
All of a sudden (no warning signs or anything...) the headphone output goes to hell...
I have an MBox1 model from 2004 (december) so i think its the 2nd generation of Mbox 1.
Usually there are signs.. it clicks on and off.. then blamo the heapdhone output (on the front and back.. 1/8" and 1/4") just go out.
so something (wiring wise) got blown..
anyone know? I am pretty handy with taking things apart, solder, twist, etc.
Let me know as this is a vital piece in my system!
-DLake
TheDLake.com
Old 06-19-2006, 09:07 PM
ajazzie ajazzie is offline
Default Re: Mbox 1 Headphone output only to one side HELP!
For both to go out simultaneously sounds like the headphones or thier cable.
Try another pair if you havent already to isolate the hassle.
Good luck.
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 06-20-2006, 07:27 AM
headphones work fine.. tested on multiple machines.. tried another pair of headphones.. they do not work.
any other suggestions?
Old 06-20-2006, 07:28 AM
Old 06-20-2006, 08:43 AM
ricupad ricupad is offline
-Were you listening to the MBox input or the output from PT?
-Have you tried listening to iTunes through the MBox to make sure it's not the software (like something muting the other output channel in PT) ?
-Do you have any plugs on the master fader?
-Also, check PT's I/O settings.
R.
Old 06-20-2006, 12:30 PM
it works fine now....
i hit the mono buttno and i heard this wacky glitch sound and it works perfect. no more problems
I HEART TECHNOLOGY! :banghead:
-DLake
TheDLake.com
Only One Side Of Output Working - Mbox 2 Pro - Help! Shams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-29-2010 10:10 AM
Mbox 2 Headphone Output is Fuzzy Fitztacular XXX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-31-2009 08:19 AM
Mbox Headphone Output - Only one Channel dvottero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-19-2006 06:40 PM
Headphone output on Mbox not independant? Equality 7-2521 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-23-2005 08:51 AM
Is it bad to headphone-amp the MBox output? futuredood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-15-2004 06:50 PM
