Change Nudge Value shortcut broken?
OK, so far I am loving everything about PT9. Seriously awesome in all kinds of ways, so I am not looking to be one of the whiners here .
However today, working on a session here, I am un-able to get the [Command+Option+Plus/Minus (+/) keys] to work for changing the nudge value. Plus (+) zooms the screen and minus (-) does nothing. Just wondering if anyone else sees this or if it's something specific to my system...?
Macbook Pro 15" 2.66 i7, 8GB RAM / 10.11.5 / Pro Tools 12 / Komplete Ultimate / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Pro / Apogee Duet |
Re: Change Nudge Value shortcut broken?
Rail
Nudge is always changed with cmd+alt+plus/minus and grid with alt+ctrl+plus/minus. Works here at 9.0.0 and with all previous versions for over a decade.
thanks for replying guys!
I found out that I had somehow turned on zooming in Universal Access (System Prefs)... not sure how that happened, but that uses the same key-commands. All sorted and working again
Hello, everyone.
I've just found out how to nudge, and also how to control grid values and nudge values from a macbook keyboard. (ctrl+opt+plus and ctrl+cmd+minus) First of all, you have to download keyremap4macbook. It will also help you with the numpad commands such as 3 for punch in, 7 for metronome, using the fn key. But it doesn't cover the keypad plus and minus signs (althought it says it does). Afterwards, you have to create a custom XML configuration file so you can type fn+plus sign on the keyboard and it will remap it to the keypad plus sign, which is the one that triggers nudge related functions. Here's an example, althought it maybe different in other keyboards, since my keyboard is spanish. After you've created the xml file, in keyremap you can load the xml file and the new configurations will show up on top. No need for a external keypad. <?xml version="1.0"?> <root> <item> <name>Fn Keyboard + to Keypad +</name> <identifier>private.swap_keyplus_and_keypadplus</identifier> <autogen>__KeyToKey__ KeyCode::BRACKET_RIGHT, ModifierFlag::FN, KeyCode::KEYPAD_PLUS</autogen> </item> <item> <name>Fn Keyboard - to Keypad -</name> <identifier>private.swap_keyminus_and_keypadminu s</identifier> <autogen>__KeyToKey__ KeyCode::SLASH, ModifierFlag::FN, KeyCode::KEYPAD_MINUS</autogen> </item> </root> Hope it helps! |
Nudge within clip - broken or setting? | admix | Post - Surround - Video | 7 | 08-19-2012 01:22 PM |
nudge broken at 23.976 and 29.97DF or NDF | Postman | macOS | 0 | 12-15-2011 03:28 PM |
Change Nudge Value broken? | Kobra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-09-2010 03:14 PM |
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? | EricHirsch | ICON & C|24 | 1 | 08-13-2009 08:07 AM |
nudge shortcut? | bmuth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-29-2006 03:20 AM |
