Old 05-06-2001, 02:35 PM
DestinysEnd DestinysEnd is offline
Default Can\'t change H/W Buffer Size
I would love to be able to change the Hardware Buffer Size to try and fix some of the other ProTools LE problems I've been having but when i open the window to do this its uneditable! All the fields are uneditable in that window. Why? I'm using Win 98SE with PTLE 5.01
Old 05-06-2001, 06:08 PM
MonologueBlue MonologueBlue is offline
Default Re: Can\'t change H/W Buffer Size
These are not uneditable. You just have to click a few times (I know there's a system, I just don't do it enough to have figured it out). I usuallly open it by clicking combinations of left and right buttons. It does pull up though.
Old 05-06-2001, 08:43 PM
Mr_Seven Mr_Seven is offline
It's from the Mac Interface. Just press and hold the left mouse button. The window will open.
Darren Valen
Cyberdream Studios
Old 05-07-2001, 12:20 AM
Thanks MonologueBlue - I had to press down both mouse keys and lo and behold!!! a menu popped up!!
Cant change buffer size shea Pro Tools 11 0 01-16-2014 11:38 AM
So, When change H/W Buffer Size...... gonsdeejay Pro Tools 11 0 07-29-2013 09:12 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Can't Change Buffer Size? sajack23 Windows 5 08-05-2012 05:29 PM
PT9 / Buffer size won't change narapo Windows 3 08-15-2011 02:59 PM
