  #41
Old 06-22-2021, 08:16 PM
MixerGuy MixerGuy is offline
Default Re: June update - hybrid info
stoked for this.... any day now i think!
  #42
Old 06-23-2021, 06:19 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
probably 31 juni
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
  #43
Old 06-24-2021, 09:52 AM
I must be doing something wrong...
I installed PT 2021.6
plus the HD driver (new one)
plus the Codecs LE (new one)
and tried to download (but could not download) the new drivers: DSX driver, CodecsPE - the My Avid repeatedly refused to let me download....
and then ran PT Ultimate 2021.6
and it seems to see my HDX cards
but is running only native, and i cant change any plugin to DSP (the old fashioned way)
plus it sees my HDX cards, but has ZERO load on them. zero usage
so how do i fix this?
thanks.
  #44
Old 06-24-2021, 11:12 AM
MrDibS MrDibS is offline
Either put the track in lightning mode or turn off the Hybrid Engine in your Playback Engine dialog.
Unfortunately, you can't selectively have some plugins in DSP and some Native within the Hybrid engine. It kind of makes the whole thing useless to me, really.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
  #45
Old 06-24-2021, 11:53 AM
loopzilla2 loopzilla2 is offline
HEAT is no longer DSP in Hybrid mode. That's a bummer.
HEAT DSP is like normal in 'classic' mode though.
  #46
Old 06-24-2021, 03:38 PM
kick56 kick56 is offline
Mr DibS, yes, at this point it all adds up to "useless to me, really" too. It's bad enough realizing that Native and DSP can't mix anymore on one track... and not only is that the same on the Master BUT if you have ANY track using DSP plugins within your tracks, you're forced to only be able to use DSP on the Master track... as you've pointed out, "useless to me".
  #47
Old 06-24-2021, 04:03 PM
Justin1524 Justin1524 is offline
Who's ready to try Pro Tools 2021.6 on a Mac M1 with a Presonus Quantum 4848 interface? Maybe me.
Justin (Proud Pro Tools Ultimate PERPETUAL license owner)
Admin
www.elevenrackpresets.com
Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
  #48
Old 06-24-2021, 04:08 PM
K Roche's Avatar
K Roche K Roche is online now
Humm not quite clear on what you are saying ? With Carbon (and they claim it is the same with HDX Hybrid) you have 3 possible selectable track states, #1 Native mode, #2 DSP mode , #3 DSP safe mode (is that not what you are seeing ?)
And with Carbon (which is always in Hybrid mode ) you can definitely have some plugin's running Native and Some running DSP ( Just not on the same track) Or is "on the same track" what you meant ?
Maybe I'm not clear on your last statement ( because if I am understanding) then in Carbon and I would assume HDX Hybrid you can have any number of tracks in DSP mode and simply make the Master Fader be in
DSP safe, and then you can use native only plugs in on it.
Like here I am running Massey Golden Master (MGM) on the Master Fader (far right ) in DSP safe mode.
Also note it automatically allows, or sees, my hardware inserts and their tracks as being DSP as well (i.e. the "M7" and the "3U".....
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #49
Old 06-24-2021, 05:57 PM
Drywsef Drywsef is offline
It would be really great if DSP tracks could be set to automatically switch back to native after recording. As it is now, they stay in DSP mode with all downstream tracks. This is a great update though!
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
  #50
Old 06-24-2021, 07:06 PM
LukeHoward LukeHoward is offline
Yes, this seems odd, it seems like it should make a distinction between DSP Mode being engaged explicitly or implicitly (through putting the track in record or input), and in the latter case revert to native mode.
On the other hand, it's cool that you can put non-DSP tracks into input or record on HDX. In theory working at low buffer sizes should now be as smooth as HD Native...
https://lukehoward.com/
Info on the AIR Hybrid Upgrade DonaldM AAX Plug-ins 8 05-12-2014 01:30 PM
Smack & Hybrid not working after OS update! KingAce Pro Tools 10 7 02-05-2014 01:21 PM
Hybrid update rabs Virtual Instruments 1 06-05-2008 12:00 AM
Hybrid Update rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-03-2008 02:19 PM
Can't Install Hybrid update or Velvet sirgant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-01-2008 01:14 AM
