How to insert external processor on Master fader
I'm reasonably versed in audio I/O, but it's not clear to me how to do external inserts in Pro Tools. I have a Maxx BCL connected to my 002 via the SPDIF in/outs. I insert the S/PDIF Left-Right insert on the master fader, but I lose all the sound, and the BCL shows no audio input. Why is audio not being routed to the BCL and back to the 002?
How do you set up external inserts in general? |
Re: How to insert external processor on Master fader
One obvious thing is that your spdif ports can't be used anywhere else in the session.
I'd also take a hard look at the Setup>hardware page. Optical format should be ADAT.. clock source could possibly be either internal OR SPDIF(RCA).. Try both.. I'd also test the thing using a send/return via a couple auxes or something just to see if the "hardware insert" aspect of it is causing a problem..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
still doesn't work. why would the optical format be ADAT when I'm using SPDIF?
But forget that for a minute. How would you insert a regular analog stereo compressor in Pro Tools? There are inputs and outputs on the 002, but no "insert" connections. |
In the I/O setup page, there is a tab for assigning ports for hardware inserts. A simpler way around this would be to assign your master to to a set of outputs and record the processed signal to a new stereo track for export.
Which output in the I/O setup corresponds to the optical In/Out on the 002? |
Well, I can get signal to the BCL by setting the output on one of the other tracks to ADAT 1-2. How come this doesn't work on the master fader?
Are you using optical or RCA connections? You have to use the physical inputs and outputs AS the inserts.. It's not really in-line inserts like on a console. It just depends on what you assign them to do from within ProTools.
Hardware insert--No audio going to 1-2 master fader. | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-06-2008 04:59 PM |
Getting a 6th insert on the master fader | badboymusic | Pro Tools TDM Systems (Mac) | 5 | 02-13-2007 09:24 PM |
EQ Coloration fom master fader insert, to all trac | BRAVO-STUDIO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-30-2004 04:21 PM |
Logic behind post fader insert on Master Buss? | McMasters | Pro Tools TDM Systems (Mac) | 10 | 09-17-2004 08:07 AM |
Outboard Gear as Insert On Master Fader | dmunach | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-14-2003 12:51 AM |
