  #31
Old 09-30-2022, 01:01 PM
scottfrankfurtstudio's Avatar
scottfrankfurtstudio scottfrankfurtstudio is offline
Default Re: Pro Tools 2022.9 "Saving ARA Data"
Originally Posted by noiseboyuk View Post
Thanks Scott.
I just went through the whole thread and there's no direct consistency with which version of MacOS people are on. Lots of reports of problems but one person on Mojave and someone on Monterey 12.4 reported no issues.
Someone on 12.5 suggested increasing the autosave time to 5 min seemed to eliminate the issue completely (if I understood right) but that didn't work for you right, Scott?
Only one Windows report where there was no pop up, but there was a hiccup when autosaving.
That's correct - increasing the Auto save to 5 Min simply made the problem occurs every 5 minutes. To get through my mission critical work last night I turned off Autosave to get through (though it's still an issue with every manual save.) Turned it back on today as Autosave really protects my clients assets (and my integrity!) LOL
  #32
Old 09-30-2022, 01:50 PM
audiogamble audiogamble is offline
Same thing happening over here. Tough to put my finger on when the problem begins happening, but as soon as I have more than a few instances of ARA melodyne then I start getting the error at every save.
I'm a chronic "cmd+s" key command person. So this is a big problem for me.
Depending on the amount of tracks you need to tune, and the length of the session, at this point it's a toss up whether this new ARA integration actually is better or worse for productivity.
  #33
Old 10-01-2022, 09:04 AM
APS APS is offline
I am having the same issues. It is always saving and impeding on my workflow.
I might need to downgrade to the previous version of Pro Tools.
  #34
Old 10-01-2022, 09:56 AM
rhodesb3 rhodesb3 is offline
Has anyone found a workaround?? (other than downgrading)
  #35
Old 10-01-2022, 11:16 AM
I've also opened a case with Support and was able to demonstrate our issues to technician Chris. I'll report back what I learn...
PT Ultimate HDX, Mac Pro, Mojave 10.14.6, 96GB Ram, 2.3.46Ghz Intel Xeon Melodyne Studio
  #36
Old 10-02-2022, 08:24 AM
midnightrambler midnightrambler is offline
Really annoying that you can pop out for lunch, come back, go to hit play and it *immediately* does a "Saving ARA Data". It's like, what the hell's it been doing for the last hour when I haven't been here?!
  #37
Old 10-02-2022, 09:03 AM
moogboy100 moogboy100 is offline
Saving ARA Data every 5 minutes.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
  #38
Old 10-02-2022, 11:12 AM
Should only auto-backup when there have been changes.
  #39
Old 10-02-2022, 11:21 AM
bobdaspit bobdaspit is offline
You're on it, Scott - thank you so much!!
  #40
Old 10-02-2022, 11:38 AM
Avid is aware of this issue and are working on a fix for the next release. Meanwhile, you are still free to use Melodyne as an insert like before(IOW, you are not forced into using the ARA version)
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] DaveGross Pro Tools 56 05-27-2022 09:05 AM
Pro Tools not importing volume with "import session data" lapieuvre Pro Tools 12 4 10-16-2015 06:02 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Pro Tools LE and "Import Session Data"? lydpik Tips & Tricks 5 09-11-2009 05:12 PM
