Old 02-02-2012, 06:41 PM
Dallas Taylor Dallas Taylor is offline
Default Solo mode bug or me?
I use "solo mode > x-or (cancels previous solo)" pretty religiously, but I can never get it to "stick". It'll last for a while, then flip over to "latch" what seems like randomly.
Is this a bug, or are there a solo mode toggle hotkey that I may accidentally be hitting?
DALLAS TAYLOR CAS/MPSE
/// Sound Designer/Mixer @ Defacto \\\ Twitter Facebook
Old 02-03-2012, 04:16 AM
rhumphries rhumphries is offline
Default Re: Solo mode bug or me?
This started happening to me once I started using the mc control and mc mix. It'll stay as long as I have the same session open, but as soon as I close it an open it or another session up it will change back to the other setting.
It feels like a bug to me.
-Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 09-23-2014, 01:50 PM
kkabel kkabel is offline
I too have this solo mode bug (even still in PT 11.2.1 / OS 10.9.8). I also use the Euphonics / Avid Artist mix. Are you also still having this problem or did you find a solution?
Old 09-23-2014, 02:35 PM
Craig F Craig F is offline
a) have you tried tossing your preferences
b) if your starting your sessions from a template how are is Solo Mode set in the template
Thank you,
Craig
Old 09-23-2014, 03:43 PM
nhaudio nhaudio is offline
I'm convinced this is related to Artist Mix and related controllers, or maybe EuCon software.
We added an Artist Mix to a stable system (like, years of stability stable), and immediately started seeing this bug. Another system that is exactly the same, except it uses a C|24 instead of the Artist Mix, never has this bug show up.
Old 09-24-2014, 01:24 AM
Yes, it's related to EuCon/Artist controllers attached. It's been an ongoing problem for years and there a bug report on Ideascale as well.
Usually restarting the Eucon app resets the solo mode to latch but not always.
Over here I have to set solo to XOR almost every time I restart my computer.
Frank.
Old 09-24-2014, 07:11 AM
quadraphonics quadraphonics is offline
We got around it by assigning a keyboard shortcut to XOR (CRTL+CMD+ALT+X). Just press it at the start of a session and we are good to go.
Randall
Frank.
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 09-24-2014, 08:20 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I think it got fixed here when I renamed the Protools 11 app in the application folder to "Protools 11" instead of just "Protools". Same with PT 10 (co-install, 10.8.5).
Anyway I used to have this same problem on our Artist edit sets, and now I don't. Same with the OSX custom keyboard commands, didn't work in PT11 before the rename.
Old 09-25-2014, 08:16 AM
That is a weird fix! I must try that. Thanks.
Old 09-25-2014, 12:37 PM
lexaudio lexaudio is offline
-Richard
Same thing happens to me. It isn't retained even with the same session, opened and closed.
LEX
Ultimate 2018.7
MacPro 12 Core 3.46 - 10.13.6
128 Gigs RAM
EFI flashed 580 GPU
3 card PCI-e expansion chassis.
Avid Artist Control
Apollo 8 Quad, Satellite Quad, Octo Card
Cranesong Avocet Monitor System.
WireWorld ProAudio Cables
HTML code is On
Solo-safing in AFL mode? Cawbaby ICON & C|24 4 01-21-2013 12:44 PM
Slow Solo mode T S Artist Series 2 02-24-2012 04:45 PM
SOLO mode changes when loading same session ! bennym macOS 0 09-14-2011 11:50 AM
AFL Solo mode and solo trim brenttrf VENUE Live Sound Systems 2 09-18-2010 12:44 AM
Is there are new solo mode or am I doing it wrong? derF Pro Tools TDM Systems (Mac) 6 03-02-2009 09:35 AM
