Old 05-23-2023, 10:04 AM
CaptCharlotte CaptCharlotte is offline
Default input path n/a but computer and Pro Tools recognize the mic
Hello,
First post, so sorry if I'm posting in the wrong thread. I've looked all over the internet, and can't figure out a solution to my issue. The issue...
I set up a Blue Yeti Mic on my mac. The computer recognizes the mic. Pro Tools recognizes the mic. However, the mic input is grayed out in Pro Tools and I cannot seem to make it active!
I'm using Blackhole as my playback engine, and have selected the mic in the Input section of the I/O settings. So I'm not sure why I can't make this input active.
Thanks for any help you can provide!
File Type: png Screen Shot 2023-05-23 at 10.02.44 AM.png (19.1 KB, 0 views)
File Type: jpg Screen Shot 2023-05-23 at 10.03.27 AM.jpg (32.1 KB, 0 views)
Old 05-23-2023, 10:59 AM
Default Re: input path n/a but computer and Pro Tools recognize the mic
Why are you using Blackhole? All your issues are likely related to that. Just use the Yeti directly as the playback engine if using its headphone output. Or if you want to use the mac output create a CoraAudio aggregate with the Mac speakers. Either way, get the Yeti working first as the playback engine, with it's headphone out as the output.
Aggregates (and Blackhole etc) have their own issues, you may not get great performance, may have CPU errors at smaller H/W buffer sizes etc.
In general these USB Mics are just not a good way to work with Pro Tools, or most DAWS. You are much better off with an interface and traditional microphone(s).
Old 05-23-2023, 11:02 AM
The Weed's Avatar
The Weed The Weed is offline
What is showing as chosen under Setup>Playback Engine? Can you choose the Yeti there?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-23-2023, 12:43 PM
Hi all, it was a sample rate issue! I had the sample rate set to 96 on the session. Once I set to 48, the input worked fine. Thanks for your insight!
Old 05-23-2023, 12:44 PM
Blackhole is just the default that seems to have been working for me. Is there a better one I should be using for Mac? I have seen the H/W butter size issues occasionally.
Old 05-23-2023, 12:56 PM
As I already explained use the Blue Yeti as the Playback Engine.
Go to Setup>Playback Engine and select the Blue Yeti as the playback engine.
If IO labels don't look correct, on each of the Setup>IO>{input, output, bus} pages select all the current paths click Delete, then click the Default button.
No Sound and input path n/a pro tools 11 iMac CameronClayton macOS 2 11-12-2014 09:30 AM
Pro Tools 10 doesn't recognize Mbox Pro 3rd Gen Input saunite Windows 2 06-29-2012 07:30 AM
Mbox won't recognize A/D converter - SPDIF "input path not available" ? casadelsueno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2010 01:48 PM
Still can't get Pro Tools to recognize any input McNabb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-05-2003 01:12 PM
Can't get pro tools free to recognize my input device emblems Digidesign Hardware & Software 1 11-15-2001 06:54 AM
