Re: FRFR Powered Speakers?
You might want to take a serious look at the EV ELX112p as opposed to the 15p. It runs about $100 cheaper and sounds great with the 11R. I have never felt I regretted going with the 12" version due to bass response - plenty of lows.
However, down where I live the EV unit is no lower than $1,100 whereas the EON is available @ $899. At these prices it's a major purchase and worth taking your time on. But, I am slowly learning about these things. I was thinking that I would take the plunge next week, but, I think I need more research, and more time at the gym (strengthening shoulders and back) . But me likes shiny new toys .
You're validating my inherent mistrust of strangers. Schecter Hellraiser 7 Diamond - Ibanez RG7620 Eleven Rack w/ ERXP |
Here's my 2 cents- When I play out I go direct and always tell the FOH guy that it's a line level signal and set my channels flat. I've had the best tone experiences when the floor wedges were E-V and EAW, I've had terrible results from JBL, they were all wood cabs loaded with 15's and a horn. When we have a band practice I use a Mackie SRM450 just for my guitar, plastic cab with a 12 and horn and the tone sucks. I think the Mackie is underpowered for my application- 7string guitar and heavier rock covers, and the plastic enclosure does nothing but make the guitar sound "fake". So I think the Mackie is on it's way out in favor of something in a wood cab with 1000+ watts of power.
Now the only FRFR system that I'm aware of sporting 1000W continuous, is the QSC K12, would you recommend this as the best choice?
the Mackie srm450 has two separate power amps; 100watts rms for the high end and 300watts rms for end. If your looking for a speaker with 1000+ watts of course the Mackie will fall short. Personally I got the Mackie because I felt it was the best sounding for the money I had. If I had more $$$ I would definately go for the EV-SXA250 or QSC K12. Thats just my opinion and Frankenbeats is probably right about the Mackie when compared to higher-end speakers.
Self Built PC: Core i5 3570K @3.4 Ghz | Asus P8Z77-V LK 8 Gigs Corsair XMS 1600 | XFX HD4870 120GB OCZ Agility 3, 2 TB WD Green Windows 7 Home Premium 64bit Pro Tools 8.0.5 M-Audio Keyrig 49 Eleven Rack w/ERXP FCB1010 | Mackie SRM450v2 | Taylor 314ce | Ibanez RG321MH | ESP Horizon NT-II DSBS |
I know you'd like to sift though a bunch of opinions and arrive at a good answer, but there's no substitute for doing you own evaluations.
Among the things I've *read*: - Some owners of older Mackie SRM450s have complained of thermal shutdowns. (I have no idea as to whether this has been resolved in the MkII series) - Lots of conflicting reports regarding HF accuracy on darned near every powered speaker... OTOH, I've experienced: - No problems at all with older Mackie SRM450s in various applications. They're practically an industry standard for low-end sound-system rentals. - Fine sound from speakers that have a reputation, e.g. JBLs, for "harsh high-end". It's not all good, though: - The Tapco Thump (admittedly a low-cost speaker) is by far the worst-sounding powered speaker I've ever used. Great if you want hyper-exaggerated bass and no midrange. Otherwise... FWIW, there are other manufacturers beside QSC with powered speakers in the "1,000 watt" range. Do a search... Also, you should be aware that the "1,000 watt" rating has absolutely nothing to do with usable power. It's good for headroom (and maybe for transient response), but the average power is *always* limited to what the speakers can physically handle. |
And, of course, for every good report for a speaker there's inevitably someone reporting a bad experience. What I'm trying to find out what the worst possible experience could be - and then figure out whether that is something I can live with. For instance, if the worst complaint was there is less headroom with a powered speaker than I can live with that. But if it a harsh sound, well no, I couldn't handle that. And I've mentioned earlier that I had first read that a 15" speaker would the better at producing bottom end, as a 7 string player I focused on that - then I read that 15" speakers are notorious for beaming sound - could I live with that, I don't know. Personally a 1,000 W speaker scares the crap out of me . But you are right of the speakers I looked at the EV ELX112P also had 1000W continuous - doh!.
My bud lent me one of them for a fews days during his down time. All I can say is WOW.....no issues with bottom end and running the 11r. Very clean, clear and superb quality. I'm getting one! |
I have to admit that I am very interested in pursuing this route as well. I have made no decision yet and for as difficult as deciding on a normal amp/speakers can be this decision is equally as difficult and expensive if not more!
Anyways, what I have been doing for awhile is reading/monitoring the Axe-Fx forums as they have many quite good discussions regading FRFR speaker choices and opinions in the Amp/Cab forum. I find at least it gives me some education and other information on this subject. FWIW as the journey to FRFR appears to be long! |
I just played a few times using a QSC K12 for my personal monitoring on stage (I borrowed it from a friend). Everyone says that this is one of the best powered speakers to use in a FRFR set up. After giving it a shot in a live setting, I don't think I am fan of the FRFR approach in general. It sounds.....OK. I normally just use in ears and I am basically looking for some sort of speaker to bring a bit of feedback to my rig when needed. I think I am going to try the Tech 21 Power Engine 60 next. I know that it won't be as flat of a response, but I think the extended high end is what is a bit off putting about the FRFR response to my ears, at least in when being used as a monitor. I don't want to have to go the racked amp/guitar cab route, especially since the 11R has somewhat limited routing capabilities when using a power amp and cab and sending a direct feed to the house.
Guitars 2010 Rickenbacker 360, 1989 Gretsch Firebird, 2009 PRS Single Cut Trem, 2010 Fender Strat, 2001 Taylor 614ce Pedalboard Fulltone Clyde Wah, Boss FV-500h, Foxrox CC Hybrid Fuzz, Foxrox Octron, Foxrox Aquavibe, Foxrox ZIM, Xotic EP Booster, Boss TR-2, Korg Pitchblack, Rocktron MIDI Mate Amps Avid Eleven Rack :: My Photos :: My Facebook :: My Church |
Powered Speakers Gone Bad | Larryboy | General Discussion | 4 | 09-19-2013 06:46 PM |
Speakers POP when Control24 is powered up | Bender412 | ICON & C|24 | 3 | 03-19-2010 01:15 PM |
What powered studio speakers do YOU use with PT | Kristine Robin! | General Discussion | 43 | 04-06-2007 09:39 PM |
Use of powered computer speakers | DrewM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-04-2005 02:27 AM |
Powered Speakers | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 12-15-2003 08:21 PM |
